amp location C5
amp location C5
Please where is the Bose amp located in C5 1999 hatchback .
I have a 99 Vert, probably the same place. Under the drivers side area. Need to take off the kick panel under the steering wheel, you will see it as you look up in the middle. If you know what it looks like it will be easy to see. If not, look on EBAY and they are all over it, so you can see what it looks like. I just don't have a pic to send, but someone else here may.
I got a 8" Bazooka Tube with internal amp built in!
It is located all the way at the back up against the bck wall between the two humps behind the net right in the center
It sounds awesome and is not intrusive fits right in there perfectly!
Thanks,Matt
Thanks,Matt
Matt - any PICS?
Sorry for the kinda dark pics but it's pretty dark stormy and raining outside right now
Here you go: I ran all the wires under the carpet and towards the front - some down the center for the radio and the power and ground wires I ran to the right down the passenger side
Let me know what you think!
Thanks,Matt
Thanks,Matt
dude, that's tight... are you using that with the stock system or did you replace your stereo and other speakers too? can i use this with my stock system?
I no longer have the stock 'RADIO' but I am still using all the stock BOSE speakers with my KENWOOD DNX6160
A BAZOOKA Tube can be used with the stock/factory BOSE stereo system (Head unit and Speakers) - the Bazooka Tube Hrness will allow you to kook it up and run it - there is also a kit you can get that will allow the factory head unit to split into RCA Jacks
Here is a couple of shots of my set-upI did not have the radio on at the time sorry)
Thanks,Matt
You're welcome! and remember that the Bazooka Tube can be used on your stock/factory system now!
Remember, I opted for the Bazooka Tube for great sound, compactability, looks, performance, sound and funtunality as well as ease of installation!
And also I wanted and All-In-One set-up, which the Bazooka Tube has - the amp is built in it so no need for extra wiring besides the Bazooka Harness
Thanks,Matt
To answer the OP's question correctly, the Bose Amp is part of the door speaker assembly. It only powers the 8" sub in the door. The device mounted under the dash on the drivers side is the Bose signal processor. The front 4" and rear speakers are powered by the amp in the radio.
Gary
Gary
Gary
Gary
Thanks,Matt
Gary
Gary
So SilverC5, What does the signal processor do? I see it always advertised as an Amp, but you say not. Just trying to enlighten myself, so I'm not giving out bad info on here.
Gary
