Need a VIN number run through GM's system
VIN = 1G1YY22G4V5109078
I just bought this and have run a carfax and all is good, but if anyone has access to GM's system can you run it through for me? The RPO code sticker on the glove box is missing so I would like to know what rear end gears it has and if there are any recalls or other interesting facts about the car.
Thanks again!
Thanks again!
http://www.compnine.com/vid.php?vin=1G1YY22G4V5109078
this will show you the RPO codes for the car.
you can PM sponge vette or gene culley to get the GM VIS info also...
here is the gear ratio listed by the RPO
GU2 AXLE,REAR,2.73 RATIO 2.73R(GU2)
Received 19,282 Likes
'20-'21-'22-'23-'24
If your car is a 6-speed, the rear axle ratio is 3.42.
Gene is a good source for the vehicle history report.
You can also contact Dennis Fichtner (forum member CeYaBye) for the info.
post up some pics!
