How do you keep the headlights up and not on
vwbjohn (02-23-2021)
Location: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
If you want them up with out having the parking lights on I believe you can use the manual **** on each motor.
Wounded Warrior Escort '11
That's not going to work either as the headlamp control module will send the command to close them when the ignition is turned off next or I think it will. Also, to get them into the mode the OP requested, everyone who responded is correct but need to tell the OP that if he's got the twighlight sentinel, it needs to be turned off in the DIC
Received 1,673 Likes
Why would you want them up with the lights off?
Received 2,673 Likes
2018 C5 of Year Finalist
In answer to an earlier post, sometimes I want the lights up after I've turned off the car/ignition in order to remove the light bezels and work on the lights, reach down to the fogs, etc., without having to unhook the negative battery cable or rotate the lights by hand.
I also have ACA HIDs and I think it would be cool to leave them up at shows, etc. without the lights on/up alert dinging...
Received 1,679 Likes
that's what i was gonna say...
My car is a canadian export... lights go up automatically when dark.. under overpass, etc... i hate it! Cannot do the twilight thing either...
Like mentioned above, turn the HL on, then rotate to parking..
Ding-Ding-Ding....We have a winner!
I love the fact that even after 6 years, I still don't know all the little C5 tricks.
Be careful you don't get your arms caught in there
Interesting. I need to try that.
Very true. These lights are so quirky in terms of electrical loads signalling them to turn on/off, go up/down, it would probably be a good idea to disconnect the negative battery cable before reaching my hand down there to do some work.
Especially with all the HID/LED mods I've performed.
Cruising
Great Tip
Whoa, that's a great tip. I want to keep the lights up for cleaning but don't want to run down the battery by leaving the parking lights on. Now I know how. Thanks
Maybe I'm just dumb, but I don't follow the parking brake trick.
If I turn the lights on, engage the parking brake, and cut the car off my lights will stay on. If I turn them to parking lights, they stay up and go off, but the parking lights stay on. If I turn them completely off they go down.
