Vortex Lip Install (Pics)
Old 06-17-2011, 10:50 PM
  #121
tslick98
tslick98's Avatar
Originally Posted by Eber
for those that arent experiencing heat issues did you keep the stock air dam IE) spring loaded center piece on or off?
Mine is on.
Old 06-17-2011, 11:12 PM
  #122
Eber
Eber's Avatar
the side pieces of mine are on but the center section is not. I asked the body shop if they had to dremel out a section and they said no. so upon closer inspection the stock (center piece) of the air dam on the spring load is not present so i guess i will throw it on and see what happens. i guess that means i have to cut the carbon piece. has anyone tried cutting the air dam instead? i feel bad trimming such a nice piece of carbon
Old 06-18-2011, 12:21 AM
  #123
tslick98
tslick98's Avatar
If you go to the first page and read GR8WHT's install, and look at his pics, you can see the part that you trim off is not that big. This is pic 8 from his write up.
Old 06-19-2011, 01:22 PM
  #124
Eber
Eber's Avatar
fixed this problem yesterday. Cut out exactly what was needed to mount the stock air dam and no problems with heat at all anymore. I will get pics up as soon as i can. Side skirts are moulded in and so is the rear carbon lip. Looks bad ***. Now all i need is a rear section in carbon to the car is lower all around
Old 08-19-2011, 12:09 PM
  #125
TheRadioFlyer
Supporting Vendor
TheRadioFlyer's Avatar
I'm curious if the radiator supports are at any point lower than the spoiler. (trying to decide if "fangs" would still be required)
Old 08-19-2011, 12:56 PM
  #126
Gr8Wht
CF Veteran
Support Corvetteforum!
Gr8Wht's Avatar
St. Jude Donor '10-'12
The radiator supports are a bit lower but you will not need the "fangs". If you install a new front spoiler and you accidentally hit a curb with the radiator supports or "fangs" you will need a new spoiler. 90% of the time I back into a parking spot.
Old 08-19-2011, 05:25 PM
  #127
TheRadioFlyer
Supporting Vendor
I see that happening to me in the future.
Old 07-25-2016, 09:03 PM
  #128
tommypenguin
tommypenguin's Avatar
Any chance you can reload the pics, they are dead links now? Yes, I know it's a 5 year old thread, hoping for the best.
Old 02-26-2017, 10:53 AM
  #129
paul17
paul17's Avatar
bump new install pics please
Old 02-27-2017, 03:42 AM
  #130
ErikwithAK01
ErikwithAK01's Avatar
Yeah, the pictures stopped working. I wanna see it too! If you use a picture loader, like photo bucket, and erase the pics from your loader before leaving it a few days, they will dissappear. You have to let it sit on the site for 5 days, or it will likely erase the used history of your images, wherever you posted them.
Quick Reply: Vortex Lip Install (Pics)
