New! C5 Corvette 3pc Lower Spoiler Reinforcement Kit! Lower Rub Strips
Platinum Supporting Vendor
I was wondering if you can clarify if the center piece in your kit comes with the spring loaded mounting piece? Mine was damaged and no longer flips down over objects and is held in place like a solid mount. Thanks in advance.
Received 19,286 Likes
'20-'21-'22-'23-'24
http://www.rpidesigns.com/shop/item.aspx?itemid=1908
Not sure if this is what you are wanting, but they do offer a reinforcement kit for the side pieces of the front air dam. I purchased these for mine and they work great.
Springs come with it??
C5 Corvette Lower Front Spoiler Replacement Kit
These C5 Corvette Front Spoilers in urethane give your Corvette a factory-fresh appearance and restore proper air flow through your radiator, solving many cooling problems. Our C5 Corvette Front Spoilers mount in the factory locations. You can use your original hardware but if it is missing or damaged you can add a hardware kit.
Your 3-piece spoiler's center piece is spring-loaded and can bounce right back in place, however, the left and right sections are not, which means they could rip off altogether if you hit a bumper block or curb. To alleviate this, we introduce the Corvette Spoiler Reinforcement Kit. These black, ABS plastic brackets take the brunt of a bump and prevent bolts from sliding through, keeping your spoiler securely in place. Kit includes one left and one right bracket and installs easily using existing fasteners.
This spoiler kit will fit 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004 C5 Corvette, including base, coupe, convertible and Z06.
Normal price: $100.00
Sale price: $94.95
Forum price: $85.46 (enter coupon code SS2007 at checkout)
Available here: http://rpidesigns.com/shop/item.aspx?itemid=1905
Thanks!!
Sale price: $94.95
Thanks!!
Sale price: $94.95
Thanks!!
Sale price: $94.95
Thanks!!
I think the springs are on the back side of what is shown in the picture, so they are not visible if they are included. Do the springs come with the center piece? I just bought mine with 113k miles on it. While it is in excellent shape, the front air dam has taken some abuse and I'd like to replace it.
#33
Sale price: $94.95
Thanks!!
Easy install while your car is tucked away for the winter!
Sale price: $94.95
Thanks!!
#34
Sale price: $94.95
Thanks!!
Sale price: $94.95
Thanks!!
#36
Do the springs come attached to the center piece or not? It has been asked multiple times. The add is not clear and does not show the backside of "what's included". A definite answer would be most appreciated so I know if I need to buy my own springs and search for a part number.
#38
You will need to order the spoiler reinforcement kit here.http://www.rpidesigns.com/shop/item.aspx?itemid=1908
It is not included with the spoiler replacement kit.
