New! C5 Corvette 3pc Lower Spoiler Reinforcement Kit! Lower Rub Strips
#42
Platinum Supporting Vendor
C5 Corvette Lower Front Spoiler Replacement Kit
These C5 Corvette Front Spoilers in urethane give your Corvette a factory-fresh appearance and restore proper air flow through your radiator, solving many cooling problems. Our C5 Corvette Front Spoilers mount in the factory locations. You can use your original hardware but if it is missing or damaged you can add a hardware kit.
Your 3-piece spoiler's center piece is spring-loaded and can bounce right back in place, however, the left and right sections are not, which means they could rip off altogether if you hit a bumper block or curb. To alleviate this, we introduce the Corvette Spoiler Reinforcement Kit. These black, ABS plastic brackets take the brunt of a bump and prevent bolts from sliding through, keeping your spoiler securely in place. Kit includes one left and one right bracket and installs easily using existing fasteners.
This spoiler kit will fit 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004 C5 Corvette, including base, coupe, convertible and Z06.
Normal price: $100.00
Sale price: $94.95
Forum price: $85.46 (enter coupon code SS2007 at checkout)
Available here: http://rpidesigns.com/shop/item.aspx?itemid=1905
Thanks!!
Easy install while your car is tucked away for the winter!
Sale price: $94.95
Thanks!!
#43
can you explain how the reinforcement kit works? the description is kinda sketchy.is it a bracket that goes on top of the front bumper cover to sandwich it between the reinforcement and the air dam? will it correct the sagging of the side portions?
#44
Use coupon code RPIDON5 and save 5%!!!!
__________________
#45
use coupon code RPIDON5 and save 5%!!!!
#46
If I am assessing this correctly, the product is made up of abs, coated with urethane.
Is this correct?
Being non rubber as the stock ones, and obviously hard like abs, I would think they would have a tendency to crack if they were to come in contact with something like a parking curb.
Can you explain this a little further?
I would hate to get them, and find that they cracked because of what I stated above.
This would be a real concern for me.
Bob.
Is this correct?
Bob.
#47
Is this correct?
Bob.
Is this correct?
Bob.
#48
Let me get this straight.
You are selling a reinforcement kit made of abs.
I take reinforcement to mean adding more protection to an existing object.
In other words, you are making an existing product stronger by adding reinforcing to it.
Does this kit replace the stock kit, or is it just an abs cover that installs over the stock kit?
Which ever it is, being abs,it is more than likely going to split if it comes in contact with a hard surface.
Could you explain a bit more for we who just don't get the principal of what it is you are selling?
Thanks,
Bob.
#49
Now, I am more confused than ever.
Thanks,
Bob.
Thanks,
Bob.
#50
Thanks for checking us out!! Use Coupon Code RPICHRIS5 for Immediate Savings!!!
#51
Hi Bob, how about you email me your phone number and I will call you and explain it to you , please email the phone number to donrpidesigns@gmail.com. Thanks, Don
#52
DECON BLUE (12-21-2020)
#53
Sale price: $94.95
Thanks!!
Sale price: $94.95
Thanks!!
#54
I'm not understanding the reinforcement brackets - I did not see them pictured on your website. I like the idea of reinforcement but don't see the difference between this and other kits avail. Any clarification would greatly be appreciated! Thanks.
#55
So, to clear this up, you are selling just the two end pieces that will reinforce the existing end pieces.
What threw me, and others off is you pictured the entire 3 piece kit.
I already fixed the problem by adding larger washers to all bolts for the end pieces, and that seems to be working fine.
Bob.
Bob.
#56
https://www.rpidesigns.com/shop/item.aspx?itemid=1908
#57
Bob.
Bob.
This link is for all 3 front spoiler pieces.
https://www.rpidesigns.com/shop/item.aspx?itemid=1905
The reinforcement pieces, which are optional are available here:
#58
#59
Thank you for checking us out!!!
#60
Get yours today!!!
