Yonaka Racing Seats Installed Pics and Installation Process
Old 03-07-2011, 07:12 PM
C5 4me
C5 4me's Avatar
You did good! I like them!
Old 03-07-2011, 09:33 PM
LSGUN
LSGUN's Avatar
O Damn im gettin me some yonakas now great prices too great thread on the install btw
Old 03-16-2011, 03:35 AM
corvettekid1973
corvettekid1973's Avatar
When your install was finished how much space was there between the seat and the trans tunnel? I'm thinking that if we can shift the seats inward towards the trans tunnel 3/4 of an inch or so that it will help decrease the amount of cutting and trimming on the outer side that's required to fit the seats and possibly even be able to leave the outside adjusting **** and seat belt plastic alone
Old 03-16-2011, 01:56 PM
ez2spd
Support Corvetteforum!
ez2spd's Avatar
None mine is TOUCHING the trans tunnel and still cut inch to inch half off side PLUS removal of seat belts...
Old 03-16-2011, 02:03 PM
corvettekid1973
Well that scratches that grand plan lol thanks
Old 03-16-2011, 10:51 PM
ez2spd
ez2spd's Avatar
I'll try and get my pictures up tomorrow... my seats are so tight against tunnel seats are not adjustable... only I drive so not an issue... don't get me wrong they will move with force lol its just a tight fit had I went half inch other way they would move easIer
Old 03-18-2011, 03:48 AM
linf94112
linf94112's Avatar
Thanks! =]
I would love to find the time to come up with a better yet strong set of brackets that do not require the factory seat bracket feet. This way I can actually just copy them and create a set.
Frank.
Old 03-18-2011, 03:52 AM
linf94112
linf94112's Avatar
I think that photo is the test fit photo w things untouched, and if not then it is the one after installation w as much shortening done as possible. Following into the later photos in the first post, you will see that I had cut off the recliner wheel for the outside altogether and welded it to the inner metal wheel to not fall out.
Also, the inside where the recliner wheel is on the final photos, it has been reduced already. The outside just had no space so it had to go inside, and while the wheel is shortened, there is still a few mm from touching the tunnel because the side and lap bolsters are already pressed against the transmission tunnel.
In summary, the outside ****'s plastic piece cant be left, and the **** also doesnt have much space unless the car's trim piece was cut.
Frank.
Old 03-18-2011, 07:56 AM
corvettekid1973
Frank.[/QUOTE]
I basically got that exact same answer from another member, thanks. For the feedback. They look really good installed
Old 03-18-2011, 09:17 AM
mickey_7106
mickey_7106's Avatar
nice write up. i would like to see them in person one day. im in Oakland. are you going to the rainbow run or abel chevrolets event?
Old 03-18-2011, 11:31 AM
ez2spd
ez2spd's Avatar
The driver side I didn't use brackets I bolted the provided sliders to the floor and put a steel brace on the under side of the car... perfect height... passenger side I used factory riser as the tunnel has a 4 inch piece coming off it... makes since when you see it
Old 03-21-2011, 05:44 AM
linf94112
linf94112's Avatar
When and where are they? Possibly can if Im not already busy the dates it takes place. Let me know, otherwise I have other days free if youre ever in SF or something.
Thanks!
  #33
linf94112
linf94112's Avatar
Interesting on the bolting to the floor. Id like to see pics of this.
Old 03-24-2011, 12:17 PM
  #34
FLYNAVY30
FLYNAVY30's Avatar
Received 2,366 Likes on 1,034 Posts
has anyone gotten in touch with Arizen to see if their universal brackets would work with these seats??
Old 05-08-2011, 02:40 AM
  #35
ClockworkC5
ClockworkC5's Avatar
im about to tackle the install this tomorrow if i get the time. im curious if anyone else has done the seats and has some more info. if i read a post correctly its possible to attach the sliders that came with the new seats to the factory bolts in the floor. is this correct. if anyone has any additional input it would be greatly appreciated. thanks
Old 05-09-2011, 05:50 AM
  #36
linf94112
linf94112's Avatar
Negative, the sliders that come w the seats dont match up to the bolts on the floor. Theyre off by a little for both sliders. The best way to match up is w a new piece of flat metal bolted to the sliders, and then to the floor.. similar to another member's install.
Old 05-30-2011, 08:41 AM
  #37
dutch911
dutch911's Avatar
Great post. Unfortunately well beyond my skill level.
Old 06-04-2011, 01:15 PM
  #38
RamAirDave
RamAirDave's Avatar
sorry it took so long to upload ONE CELL PHONE PICTURE.. but they are installed and I LOVE THEM!!! Will have better pictures tomorrow once I get out the EOS
Guys,
I have this car now and these exact seats and belts are for sale. I am simply too big for them.
All the cutting and measuring and everything will be done for you and you will save some money as I just want to trade straight across.
Want to trade for some C6Z or C5Z stock seats in excellent condition. these are about 2 months old.
I am located in OKC.
Thanks!
Old 06-04-2011, 01:16 PM
  #39
RamAirDave
RamAirDave's Avatar
Do you have a Z06?? I have family that travels to Ohio regularly and we could work out a trade on the seats if you want?
Quick Reply: Yonaka Racing Seats Installed Pics and Installation Process
