DIC - Resetting Oil Life Remaining
After my annual trip to the dealer for an oil change on my 01, there was a message on the DIC "Oil life remaining 100%". I tried to clear the message by holding the rest button, but now the message says "Oil Life remaining .....".
How do I clear the Oil life message and get back to the screen that displays the (default) odometer setting?
Thanks,
Mordi
Thanks,
Mordi
it was ok when it read 100%
read this thread and try some of the suggestions.
http://forums.corvetteforum.com/c5-t...resetting.html
If it reads oil life 100% that isn't a message to be reset, you just need to toggle back to your preferred display. So I believe you would just tap the Trip button until it goes back to displaying the Odometer reading, or maybe the OD reading is under Gauges, I forget now... Either way cycle through the proper display until you get to the OD reading.
St. Jude Donor '10
Received 1,672 Likes
The owners manual is a wonderful thing to read and use.
