Fuel Gage problems
Fuel Gage problems
I recently purchased a 2002 Corvette coupe. Full tank of gas. Once the gas gage went one tick past 3/4 tank the gage went to zero and got the low fuel waring. I filled up to ensure I infact had a full tank of gas and the gage began to work again. Gage went back to zero when the gage went one tick below 1/2. Filled it again and the gage is again working. What is the problem? Dealer told me to disconnect the positive lead of the battery and that should reset the system. Has anyone experienced this problem?
I've got the same problem and by reading out the DIC (codes) I've got a problem with the right side fuel transmitter.. It's fairly easy to replace but costs around $360.. The left side is a bit cheaper.. About $100 for parts.
You can try the techron, it's easy, and fairly cheap but I'm not sure it really works.. But sure can't hurt.
Good luck..
Good luck..
Go to you local auto parts store and get a bottle of Techron fuel system cleaner. Add it to your next tank of fuel. You most likely have deposits on the contacts for the fuel level.
I have no intention of paying someone to tear into my vette and then possibly screw up something else in the process when a simple fuel additive will fix the issue.
Don't forget you're also getting the benefit of complete fuel system cleaning along with fixing your gauge problem. That's a 2fer!
Good Luck!
Location: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
For all you new members with fuel gage issues, It is best to use top tier fuel, If you have access to Chevron gas that would be your best bet, Next I would say Texaco or Shell. What is happing is the copper of the fuel sensor gets a sulfur build up on it and quits reading correctly, If you don't have access to the top tier stations do the next best thing, And that is to get Techron in a bottle from your local parts house, It might take a few treatments if your sensor isn't too far gone.
Just my 2 cents.
Mr.Bill
Just my 2 cents.
Mr.Bill
St. Jude Donor '05-'06
What he said ...... Oh your dealer is a moron too
Get the 20gal treatment bottle too, it took 2 to fix mine, Run the fuel down to below 1/2 before you put it in or it won't mix right and get to the right side tank sensor that is causing your issue and make sure you fill it to the brim run it down to below 1/2 and repeat till it stops doing it. Also good to let it sit a few days with the tank full w/Techron in it. It will take a few sweeps of the sensor arm to dislodge the corrosion is the reason it may take several treatments.
Received 19,309 Likes
'20-'21-'22-'23-'24
I agree with trying the Techron first - it might remove the sulfur deposits that most likely have gotten on the sending unit. If that doesn't work, may have to end up getting the sending units replaced.
I got about 200 miles when the fuel gauge went to zero. I know you're suppose to put it in with a near empty tank and run it until it's near empty again. How many miles can I go without running out of gas? I drive it pretty smooth and don't get on it very much. Still trying to figure out mileage with a semi working gas gauge. Did anyone have issues with the gauge hanging up as well?:
Jumper, I, too, had the guage issues. 2000 Coupe. I got my answer from the forum, too. Used Techron, began using Chevron regularly and all has been good. When we moved to Colorado Springs, I couldn't find Chevron. I am told Shell gas has the same additive. I use Shell most of the time and put a can of Techron in every so often. No issues for the past four years....."knock on wood". Good Luck to you.
Check out the corroded traces... the dark colored gunk. These traces should be as shiny as a brand new silver dollar,
If your fuel gauge is correct, you are driving a knock-off. The only way to confirm that you are driving a "Genuine C5" is if the gas gauge only works occasionally as a compass.
