HID Low Beam Replacement Kits ^^On Sale $69.99^^
Old 04-11-2011, 08:50 PM
0corvettemods1
Former Vendor
corvettemods1's Avatar
St. Jude Donor '12-'13
Default HID Low Beam Replacement Kits ^^On Sale $69.99^^
If you're tired of the poor lighting you get from the OEM bulbs in your headlights, its time to upgrade to HID's!
Our HID kits are complete with 100% digital SLIM ballasts which are the thinnest on the market and bulbs rated at 6000k (white with bluish tint)
All of your HID kits come with a 2 year replacement warranty as well.
You don't need any mechanical skills to install our kit. No cutting or drilling is required either. Install takes under an hour for most.
These kits are currently on sale and marked down to $69.99 while supplies last
Click here to order:
http://www.corvettemods.com/Corvette...it_p_5530.html
New 55w Ballast Options Now Available too!
Now you can also add our Fog HID conversion kit to get your lows and fogs to match up perfectly! Click below to go to the sale thread for the FOG HID's!
http://forums.corvetteforum.com/c5-g...e-69-99-a.html
RECENT CUSTOMER INSTALL!
Comparison to stock
Old 04-16-2011, 02:54 PM
04C5comm
04C5comm's Avatar
Default Order
OK I ordered mine, not sure why I'm the first one??? Sounds like a good deal to me..
Old 04-16-2011, 02:56 PM
0corvettemods1
Former Vendor
You're not the first! Thanks for your order
Old 04-19-2011, 09:08 AM
xpunter83
xpunter83's Avatar
ordered mine yesterday, along with the fogs. Cant wait to have headlights that work!
Old 04-19-2011, 12:30 PM
Kutal
Kutal's Avatar
I take it that this just plugs into the 9006 harness, mount the ballast, and twist the capsule into the stock housing? (plug and play)
I have OEM HID on my DD, I thought the headlights were broke when I first drove it at night.
Ordered mine, hopefully I can install it without too much hassle.
Old 04-19-2011, 01:06 PM
0corvettemods1
Former Vendor
Install is very simple, youll love this mod!
Old 04-19-2011, 01:20 PM
bikgc
bikgc's Avatar
Does anyone know the legality of having these in California?
My stock bulbs are going out and I'm looking to upgrade, just worried about getting a fix it.
Old 04-19-2011, 07:16 PM
ricknyc23
ricknyc23's Avatar
do you have the install instructions?
Old 04-19-2011, 07:17 PM
0corvettemods1
Former Vendor
Sure, PM your email address to us
Old 04-19-2011, 07:47 PM
GK
GK's Avatar
Can one purchase bulbs at a different kelvin rating as to not have any blue tint?
Old 04-19-2011, 07:48 PM
0corvettemods1
Former Vendor
We can do a 5000k kit which is more white or a 3000k kit that is yellow
Old 04-30-2011, 12:00 PM
rmreece
rmreece's Avatar
Has anyone installed there HID Low Beams? How do you like the new HID's? Any regrets? How did the installation go and how long did it take? Did you order and install the optional resistor too?
Old 05-09-2011, 12:44 AM
0corvettemods1
Former Vendor
It's recommended to get the resistor if you dont want to flash your highs for the buckets to close.
Old 05-13-2011, 09:01 PM
Kutal
Kutal's Avatar
Install took around 3 hours for me. Difficult part was taking the HID bulb and trying to put it in the socket without the bulb touching anything. I removed the light shroud, painted cover and the cover support below it. You need thin arms especially trying to get the bulb in there without scratching the bulb on the housing around the socket hole.
Old 05-13-2011, 11:53 PM
DP77Vette
DP77Vette's Avatar
St. Jude Donor '10
Something else to spend $$ for. Probably bite the bullet in a day or two.
Old 05-17-2011, 09:46 AM
Trigger Creep
Trigger Creep's Avatar
I've been too busy to figure out where to mount the ballasts, etc. Does anyone have pics or a link to a detailed install?
If its left up to me, I'll have it apart for 3 weeks still scratching my head.
Old 05-17-2011, 10:23 AM
0corvettemods1
Former Vendor
Most get some Velcro and stick them under the buckets, they are so slim it's easy to hide them!
To HID Low Beam Replacement Kits ^^On Sale $69.99^^
Old 05-18-2011, 01:34 AM
04C5comm
04C5comm's Avatar
The install would have gone much easier if they would have added just 3-4 inches to the wire extensions. I chose to mount the Ballasts on the frame rail on the radiator side. the trouble is drilling a small hole and tapping it down in there. the lights are great, much brighter than stock bulbs, the pattern with the stock glass isnt the best but still better than stock. well worth the work and cost. you really do need small hands for this one.
Old 05-24-2011, 07:48 AM
Kutal
Kutal's Avatar
I mounted the ballast right behind the bucket on the plastic cover above the tire. There is just enough clearance for the hood.
Re aim the headlights after installing it, or you will be blinding oncoming traffic. Spray WD40 on the adjust nuts before you turn it, or you will break them.
Old 05-24-2011, 02:47 PM
warpster
warpster's Avatar
Do you have any to with the euro bulbs (H4)?
Quick Reply: HID Low Beam Replacement Kits ^^On Sale $69.99^^
