View Poll Results: Unexpected Issues and Their Costs
Constant repairs being made
24
5.50%
Moderate repairs being made
54
12.39%
Seldom repairs being made
107
24.54%
Very seldom repairs being made
251
57.57%
Voters: 436. You may not vote on this poll
Common C5 Issues. What are/were yours?
Electrical issues are my worst nightmare! I never had electrical issues with my Toyotas or Hondas ever. It seems to be an American or Euro car thing as I rarely see them with imports.
Is there any possible way to remove all that junk?
...I really only need roll up windows, ac, heat, and cruise.
Removing the electronic nannies may be possible but you'll have all kinds of codes, warning lights and sounds to constantly remind you that they are missing or disconnected.
2002 Z06. I have had the car for 1.5 years and have put on 3k miles.
Repaired:
EBCM
Column lock
Broken Valve spring
Air pump shut off valve
Headlight gear
Oil pressure sensor
Sticking clutch
Leaking roof to door window seals
Head light gear.
Still to repair:
Dropped HUD
Horn contact
Replace fuel level sensor after many bottles of Techron.
Probable clogged passenger side fuel pump
LED's in HVAC controls
Rocking seat
No indicators until I jerk off the hazard lights
Just got a SECURITY light and B2721 while driving last night
I am pretty sure I have had more common issues. I have also repaired many other things that are not as common. This has definitely been my worst car maintenance wise. Good thing it is fun and cheap to fix.
Repaired:
EBCM
Column lock
Broken Valve spring
Headlight gear
Oil pressure sensor
Sticking clutch
Head light gear.
Still to repair:
Dropped HUD
Horn contact
Rocking seat
2002 Convertible w/74K, I am the original owner.
Headlight Gear (1)
Gas tank jet pump
Water pump
Leaking Diff gasket (twice)
Oil pressure sensor
And thats about it. For 9 years + and 74K I consider myself very lucky. This Vette is one of the best cars I've ever owned. For all the things GM got wrong in the past they made it up with the Corvette, just a very well made car.
P.S. The car is completly stock with exeptions to lighting.
Headlight Gear (1)
Gas tank jet pump
Water pump
Oil pressure sensor
1 Post
Fixed:
Column Lock relay
Oil Pressure Sender (lasted a week, about to do it again)
End Links
Rebuilt TPMS's
Issues:
Both window regulators
Fog Lights don't work
Intermittent drivers side door lock
Column Lock relay
End Links
Rebuilt TPMS's
Issues:
AKA "The CLOWN"
Only problems I got are the turn signal flasher, witch was just fixed and the doors with unlock with key fob, but they will not lock, other than that, I've had the car 4 years with no other problems!
I've owned my car about 6 months or so, but I've done:
Harmonic dampener
A/C belt tensioner - probably went out due to bad harmonic dampener
Oil Pressure sensor
Air Check valves (Code P1416)
I've got a intermittent leak on the drivers window. If I roll the window down then back up after closing the door, it appears to stop.
Harmonic dampener
Oil Pressure sensor
steering column lock
oil pressure sender
window electronics
so far, those seem like the most apparant. are they expensive fixes? the last thing i want is a car that costs a lot to keep functioning properly; which rather those monies could be used for mods.
powertrain, drivetrain, and suspension are all solid is what i belive. it's kind of a drag to hear that it's the little micky-mouse stuff that fails- getting "nickel & dimed".
keep the replies coming...
good info and feedback so far!!!
oil pressure sender
window electronics
I have a 97 with 76k miles - daily driver. Had it 4 yrs. Only Major issue was the clutch slave cylinder failue -- very expensive to fix as the whole trans rear axle and torque tube has to come out.
Had other typical minor issues like gas gauge (techron keeps it working) and passenger window sticking (whack on the door "fixed" it)
Also had the column lock up - fixed under recall but $50 CLB would have prevented that.
GREAT 14 yr old car overall.
I searched about that on these forums too. Is there a viable solution to resolve the grounding issues? Like doing a big 3 upgrade or upgrading the thickness of major ground wires?
#34
I have had my 01 Vert about 5 years. About a year ago I started having some electrical issues. The car sits sometimes for a month or more without being driven. I found that if I keep a battery tender hooked up most of my electrical issues have gone away. Letting the battery get weak causes all sorts of problems.
#35
#36
#37
When an ECBM goes out, does it give an indication on the instrument panel? Or is it something you feel when your driving.
#39
1998 Coupe 135,000+ miles (daily driver), only 3 problems:
-one headlight gear
-one oil pressure sensor
-leak in plastic radiator fill tank
Has been my most reliable car !
-one headlight gear
#40
Perhaps you'd be happier with one of those great Toyota Prius things that NEVER have electronic issues - oh, wait, that's right...
I may be reading too deep into it, but your comment borders on racist, I hope that's not how you meant it.
