Just finished my Radio Bezel Carbon Fiber 3M Vinyl
UPDATE:: 4th try. No blemishes at all this time around. Used one single sheet.
I did my door openers this time around also:
3RD TRY
Well after two tries with not so good of an outcome I was finally able to get it right this time with coolarrows advice.
This is only the main piece. I'm going to do the ashtray and drink lids this week and install on Saturday.
3RD TRY
It's been trial and error so far. There are so many curves and stretch points, it's VERY unforgiving. One mess up and you pretty much have to scrap it and start again. You can patch if you like but, personally, I don't want to put anything in my car thats not perfectly done. It's easily the hardest of the DIY projects I have done so far. I have to do a little research on possibly making a mold of the radio bezel's ashtray and din areas to see if I cant make that part somewhat easier. however, I'm going to do another one this comming weekend. I'll take pictures on that one.
Location: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
very well done...definitely take some good photos for us...that is a great material to use all over the interior...
Received 1,674 Likes
Looks good so far!
Pics of installed?
I work with the carbon vinyl but not 3m. I've got a vendor that I've used several times that's very similar to feel and quality of the 3m. Never done any anything for the vette though. I've done a few small pieces for bmw's and such.
The heat gun is so important wrapping interior pieces and complicated curves...
Received 19,282 Likes
'20-'21-'22-'23-'24
Looks great - I can only imagine how difficult it was to get that right with so many curves to work around.
I've done a few parts but the 3m vinyl always seems to lift. Did you use the 3m primer or just wrap it directly on the bezel?
I will be interested to see if it stays in place on a hot summer day....
I hope it works out for you, it looks nice, the typical hydrocarbon look is just a little too "glossy" for me...
You bring up a good point about hot summer days. I put the bezel in the trunk of my car for a few days to see if it comes up or the edges around the ash tray pull back. I did use super glue on some edges, not around the ashtray though. Gonna give it a few days and check the results.
I have found something that might be the answer I'm looking for though. personally, I dont want to use super glue as an alternative adhsive. I ordered a Seat-it-pen a few moments ago. I'm going to wait for that to come in before I make another Cf wrap attempt.
I totally agree on your comment about the hydrocarbon look. It's fantastic work but the clear coat is to glossy for me. The glossy look of the carbon fiber vinyl blends better with the leather look of the interior imo.
Pics of installed?
As soon as I get my 94 primer order in I'm going to give it another try and take step by step pics this time around. I posted my full interior in another post but here is what the Radio bezel looks like Installed.
Here are the pics showing the three areas I screwed up this try.
Still kinda getting used to it. I do like it better then the clearcoated stuff though. The Vinyl has a shine to it that doesn't really show up on pictures for some reason, but it still has a leathery look to it. If I decide to keep the look I'm going to finish covering the rest of the console area and the door openers.
1 Post
St. Jude Donor '12
Yep. Heat Gun is the key
Looks good.
I used the 3M DiNoc on my door pulls and the entire center console, that I think turned out great. Its been in the 90's for several days here in Texas and have had no problem with it lifting. I did not use any primer just cleaned and washed the parts with mild soap and warm water. Your right it was a real pain getting everything bubble free and smooth, but if you take your time and use a heat gun it will come together.
