Forgstar f14, or TSW Nurburgring for flared?
Location: ALL governments are legalized mobsters, so doesn't matter where I live :(
Does anyone have any clue if either of these wheels come in a high REAR offset to fill in TPE or L5 fender flares without having to run a wheel adapter/spacer???
Thanks.
Thanks.
I'll let you know what I find out. I'm looking at a 18/19 combo, interestingly the Forgestar website lists a 19x12 rim but that size isn't listed on any threads on the forum. 18/19 is my preferance but I might consider a 19/20 after reading some threads on here.
http://forums.corvetteforum.com/c6-c...w-on-sale.html
Available Sizes
18"
18×8.5 offsets from +26 to +50
18×9.0 offsets from +20 to +55
18×9.5 offsets from +26 to +60
18×10 offsets from +16 to +42
18×11 offsets from +23 to +55
18×12 offsets from +36 to +68
19"
19x8.5 offsets from +26 to +48
19x9.0 offsets from +20 to +55
19x10 offsets from +20 to +44
19x11 offsets from +23 to +55
20"
20×8.5 offsets from +26 to +50
20×9.0 offsets from +18 to +56
20×9.5 offsets from +7 to +43
20×10 offsets from +31 to +69
20×10.5 offsets from +20 to +55
20×11 offsets from +48 to +81
20×12 offsets from +39 to +75
This might help when you talk to the vendor...found this on another thread in the c6 section:
Available Sizes
18"
19"
20"
Available Sizes
18"
19"
20"
Did the vendor verify that they will fill out the flare without requiring a spacer? Will he be held liable if they don't? Yup, 18/19 Let me know what they quote you.
Night Owl for life
Received 3,241 Likes
i've done tons of research on this very subject.
i run L5 rear quarters and have been *this* close to ordering a set of f14s, but sometimes life gets in the way so they will be put on hold for a while.
This is what i came up with for a perfect fit for my future setup:
fronts = 19x9 +55mm w/245/35/19 random-brand tires
rears = 20x12 +42mm w/335/25/20 michelin ZR1 runflat tires
i'm going with the narrower 19x9 for the front because the 19x10 does not have a high enough positive offset to tuck into the front fenders.
the 20x12 +42mm is 1.125mm further out than the setup i run now (19x12 +59mm with 5/8" spacer) so that's pretty much perfect for me. they are also available 20x12 +45mm but that would be 1.875mm further in from where i sit now.
you can also use a 345/25/20 rear tire but i've read that the zr1 tires are so good that i want to try them.
it appears that the 19x12 sizes are very new because they were not available last time i researched them. you should be able to get the exact same offsets that i mention in the 20" sizes above. you can also get an 18x9.5 +60mm for the front and use a 275/35/18 front tire.
good luck with your decision. i think that the tsw wheels look good but i'm really drawn to the concave design of the f14.
try www.raderwerks.com - not the exact style you were looking for but their 3 piece wheels can be custom made to any specs - their BBS LM reps are ridiculously nice
also www.rotiform.com does the same type of thin
Night Owl for life
JD this is great stuff! If anything I would be looking to do the 19" rear instead of 20". Did you speak with forgstar on this or did you come up with your own calculations? BTW, I've admired your car when I first came on the forum...I still remember it before it had the TS rear bumper, and I was thinking, MAN do I want my car to look like that! Very clean, simple, and beautiful!
those are my own calculations based on my current wheels.
now that i know the 19x12s are out i might be joining you and reusing my current 18/19 tires.
Maybe we can get a group buy, i'd be interested in a set of 18x9.5+50 and 19x12 +59. I think the +59 offset would work on a non flared rear c5, also this way we can get more guy's interested so that the group buy would work.
-CC2
-CC2
UNDACOVA, JDM, keep us informed.
Cheers mates
Night Owl for life
that stock c6 z06 size sticks out.
Thanks for your input & I too love your set up
Night Owl for life
^ no, the 18x9.5 +60mm will fit great up front.
I have 19 x 9.5 with a 265 nitto on front and tucks perfect , the rear is a 20 x 12.5 with a 345 and it sticks about 1/8 out on the 12.5 , you should be nicely tucked with the 12 and what I should have done
