2001 bose radio lights are out
I have a 2001 coupe with the factory bose head unit. The display and the radio itself work fine, but all of the lights are out. I removed the radio and opened it up to find that all of the bulbs are fine. I am wondering if the BCM controls the illumination circuit independantly of the display. Has anyone else had the same issue? Could it be the BCM or a circuit inside the radio itself? Thanks for any help.
Hope this helps.....by the way...my vert is also a 2001
Received 19,296 Likes
'20-'21-'22-'23-'24
As another option, you could contact JW Motoring and see if they can not only fix the lights, but also maybe put in some LEDs while they are there.
