New Product! C5 Corvette No Drill Stealth Splash Guard Kit!!
Old 05-14-2014, 01:53 PM
  #61
2ooo-C5
2ooo-C5's Avatar
Easy to install and they staid on at speeds over 120 mph.
My fiberglass thanks you.
Old 05-17-2014, 09:25 AM
  #62
jdvann
jdvann's Avatar
Default Super Stealthy
They work great!
Old 05-22-2014, 10:16 AM
  #63
imgn tht
imgn tht's Avatar
St. Jude Donor '13, '15
This thread needs more pictures. Anyone got a shot straight on from the side? Looks like those using them are on OEM wheels. Will these work with 19x11's out back when mounted in the intended placement? I'm running 295 wide tires.
Old 05-26-2014, 09:37 PM
  #64
RPI Designs
Platinum Supporting Vendor
RPI Designs's Avatar
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16 -'17
Originally Posted by jdvann
They work great!
Thanks for the great pictures!!
Old 05-29-2014, 07:27 PM
  #65
bgp2157
bgp2157's Avatar
As per your refund policy, can these be returned if they don't fit correctly or fit poorly?
Old 06-02-2014, 03:44 PM
  #66
RPI Designs
Sure, no problem. We've sold a few hundred sets and all happy customers. But no problem at all.
Old 08-15-2014, 09:20 AM
  #67
tdogg21
tdogg21's Avatar
2017 C3 of Year Finalist
Will you be in Carlisle this year? If so, will you have these in stock?
Old 01-23-2015, 02:18 PM
  #68
STI990
STI990's Avatar
Anyone use these with a 315 in the front and rear? I want to buy these to reduce the damage to the fenders with my 315 square setup, I am not a fan of the larger splash guards. Anyone have pictures with these with a 315?
Old 05-27-2015, 08:00 PM
  #69
gulfstrings
gulfstrings's Avatar
They work great!
Did you place any kind of protective materials between the guards and your painted surfaces?
Have you looked underneath the guards for any scratching, etc., of your paint?
Thanks.
Old 11-23-2015, 10:26 AM
  #70
Clancy209
Clancy209's Avatar
What is the material, rubber, plastic, is it flexible enough to take high curbs w/o snapping off?
Old 11-23-2015, 08:58 PM
  #71
Dag Skagney
Dag Skagney's Avatar
They are plastic and they are flexible. They fit and work fine for what they are. I think if I hit a high curb these inexpensive splash guards would be the last thing I would be concerned about.
Old 01-26-2016, 09:18 PM
  #72
Clancy209
Clancy209's Avatar
Think I mentioned this before, I just installed a set on my C5. I like the look however, Disappointed in rears should be the same height and width as front. Maybe almost to the rear marker light, then taped in, should be wider at bottom for max under protection.
Old 03-18-2016, 08:35 AM
  #73
RPI Designs
Originally Posted by RPI Designs
C5 Corvette Splash Guard Kit - Stealth Style, No Drilling Required
This C5 Corvette splash guards kit includes four splash guards, two for the front wheels, two for the rear wheels. No drilling or glue required. These C5 Corvette splash guards use stock hole locations to mount in combination with provide clips. We provide new push clips to install the rear splash guards. The front splash guards you simply back out the two inner fender bolts, put the splash guard in place and tighten back down. Installation takes less than 10 minutes!
These splash guards are made for the C5 Corvette, they are not a universal splash guard kit. These were designed to follow the body lines of the C5 Corvette and to remain almost un-seen, yet provide protection.
This 4 piece kit will fit all 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004 C5 Corvettes, including base, coupe, convertible and Z06.
Retail: $44.95
Intro Sale Price: $39.95
In Stock here: http://www.rpidesigns.com/shop/item.aspx?itemid=1949
Old 05-20-2016, 08:33 AM
  #74
caddman11
caddman11's Avatar
I purchased a set about 6 weeks ago, no damage to any painted surfaces and took about 10 minutes to install. they are very ridged, could look a little better, but they do protect from rocks and road gunk.
Old 09-09-2016, 09:38 AM
  #75
RPI Designs
These are a quick and easy way to protect you paint.
Old 12-11-2016, 12:39 PM
  #76
TripleBlackZ06
TripleBlackZ06's Avatar
Use coupon code LANA5 to save 5% at checkout!
How long is the sale, looking to order after holidays ?
Old 10-14-2017, 12:17 PM
  #77
RPI Designs
Use coupon code LANA5 to receive 5% off your order!
To New Product! C5 Corvette No Drill Stealth Splash Guard Kit!!
Old 10-14-2017, 05:23 PM
  #78
mrlmd
mrlmd's Avatar
I have had these on my car now for a couple of years, painted them with Duplicolor silver colored paint for vinyl which matches my Sebring Silver car perfectly. They have held up great, no cracking or breaking, stay in place, do the job protecting the body from stones and sand, and are barely noticeable on my car. Very easy to put on and I would highly recommend them and the price is a big plus.
RPI Designs (10-16-2017)
Old 12-06-2017, 12:27 PM
  #79
RPIDON
RPIDON's Avatar
Thanks for Checking us Out!! Use Coupon Code RPICHRIS5 for immediate discounts!!!
Old 12-07-2017, 08:34 AM
  #80
Ramets
Ramets's Avatar
Might be what I've been looking for. I didn't like the idea of having to remove the rear wheels, and drilling. I just placed my order. So we'll see.
Quick Reply: New Product! C5 Corvette No Drill Stealth Splash Guard Kit!!
