Anti-Venom 6 Speed Shifter Modification (Procedure)
Old 08-17-2014, 07:29 AM
  #261
black match box
black match box's Avatar
Thanks.
Old 08-23-2014, 04:29 PM
  #262
tommypenguin
tommypenguin's Avatar
I installed two washers today, I guess my order was only for two washers and not 10. As many others have attested this made my shifter sillky smooth to shift into gear while remaining firm. Thanks for the suggestion, made a night and day difference with my mgw short shifter.
Old 08-23-2014, 06:17 PM
  #263
Toque
Toque's Avatar
Location: Wylie TX --> Less is More, except under the hood !
Old 08-23-2014, 08:00 PM
  #264
4XLR8N
Pro Mechanic
4XLR8N's Avatar
Received 1,652 Likes on 1,209 Posts
Did the same mod (only 1 washer) after having the MGW shifter about a year...definitely helped!
Old 09-28-2014, 08:30 PM
  #265
Stroker87
Stroker87's Avatar
any one with a hurst shifter do this?
I just installed a RPM level 5 m12 and getting it into gear is a little firm for my liking (not side to side) shifting from 1 to 2 and so on
Old 09-29-2014, 08:31 AM
  #266
Toque
Toque's Avatar
Any short shifter will benefit from the Anti Venom mod.
Its easy and cheap to do, and easily reversible.
Toque
Old 09-29-2014, 09:21 AM
  #267
bjones7131
bjones7131's Avatar
I installed and saw no difference so I removed and put back stock, go figure, I was hoping to get a smoother transition between gears, not.
Old 09-29-2014, 09:28 AM
  #268
Toque
Toque's Avatar
Do you have a short shifter ?
Toque
Old 09-29-2014, 09:47 AM
  #269
bjones7131
bjones7131's Avatar
No, bone stock.
Old 09-29-2014, 10:23 AM
  #270
Toque
Toque's Avatar
No, bone stock.
Likely why you did not notice a difference.
Short shifters by nature will be a little more stiff to shift.
The Anti Venom mod will loosen them up a bit and make them feel like stock again.
They are just shorter and better shifting...
Toque
Old 09-29-2014, 02:26 PM
  #271
chassed
chassed's Avatar
Didn't read the whole thread, but how well would this work with a C6 Shifter?
Old 09-29-2014, 03:44 PM
  #272
Toque
Toque's Avatar
Hopefully someone with a shorter C6 shifter will chime in, but I bet it would help.
Toque
Old 09-29-2014, 11:11 PM
  #273
chassed
chassed's Avatar
Alright, I'll try it & report back!
Old 09-30-2014, 01:39 AM
  #274
got-20z
got-20z's Avatar
I did this last week. I did it after installing a stock C6 shifter and now it's just awesome all around. Looks and feels great.
Old 09-30-2014, 09:37 AM
  #275
roscoe118
roscoe118's Avatar
Originally Posted by got-20z
..I did it after installing a stock C6 shifter ...
I added one washer with a shortened C6 Z06 shifter, and had a noticable improvement. After installing a B&M, it felt too firm again, so I installed a second washer and love it...
Old 09-30-2014, 11:31 AM
  #276
got-20z
got-20z's Avatar
Yeah I bought the 2 pack of washers but only put on one. I might try the second one the next time I already have my car lifted up for other work. Like you said, I've heard some say they used two washers and love it.
Old 10-07-2014, 01:50 PM
  #277
jackthelad
jackthelad's Avatar
Minor point and question: 3/4" is not 20mm, it is 19mm, so M20 3/4" is not strictly accurate. Anyone measured the inside diameter of the recommended washers? Or know what the actual thread is? Thanks.
To Anti-Venom 6 Speed Shifter Modification (Procedure)
Old 10-08-2014, 12:52 PM
  #278
jlturpi
jlturpi's Avatar
Nice thread.
Old 07-12-2015, 04:09 PM
  #279
Stroker87
Stroker87's Avatar
cant be leave I waited so long to get this done, my hurst short shifter was kind of a pain when putting around in traffic (when aggressive it rocks) installed one wash and its so much better i'd say i lost 40+ % of the notchy firm shifting feeling it still has some I might try one more just to see but i'm thinking it feel to loose
total time spent 20 minutes (15 was getting my tools out and packing them when i was done)
Old 07-13-2015, 05:32 PM
  #280
whit1
whit1's Avatar
Did this today. Have a 13 Gs with Mgw shifter. 1 washer made a nice improvement in shifting ������
Quick Reply: Anti-Venom 6 Speed Shifter Modification (Procedure)
