Help - oil plug bolt won't come loose.
The car was serviced under gmpp at a dealer some time ago. they had to drain the oil.
They plug is in there so tight I can't get it out.
Any tricks to pulling this plug without destroying it?
I had to use a breaker bar on mine last week when I did my first oil change. The previous owner did not do his own changes either. I have a 1/2" breaker bar and adapted it down to 3/8" so that I could get a socket on it. Still it was pretty damn tight. Not no more.
How in the world do you get an impact on it? The crossmember right in front of the bolt.
I tried my big wrench, and it started to bite into the bolthead so I sat it down.
I think at this point the only thing I'm going to do is damage my car trying. I'll contact the dealer that caused this problem and see what they say...
I triedo ne more time with an extension, reducer, and my big torque wrench. I swear I've taken off axle nuts that were easier.... But it's out. Threaded in and out nicely after breaking it so I think it's OK.
I don't know what some of these idiots at dealers are thinking..
But the other tips may work if you just want to do it home. You dont really have to wack the breaker bar with the hammer, I think its the vibrations that loosen it rather than the force of the blow.
Good luck.
Received 19,295 Likes
'20-'21-'22-'23-'24
If the dealer did the last change, take it back to them and tell them to loosen the plug for you. I would insist they do it no charge as there is no reason to tighten it down that tight.
What did they use to get it so tight -- an impact wrench? That tool, in the hands of most people, is a terrible thing.
Resident moron
