Fast 92 owners with LS2 Throttle Body... Install Question ?
Guys
Just doing more research on my future install.
There is a rubber hose that plugs into my LS6 throttle body. The LS2 TB does not have a place to put this hose.
Where did you put your hose ? Did you put it into the air coupler before the TB ? I'm not even sure what its for...
Thanks !
Toque
Thanks !
Toque
It is the source of fresh air for the crankcase. The LS2 engines have a hose (pre-molded nylon) coming from the coupler. It has a squeeze type quick-disconnect on one end (coupler end) and the other end goes to the valve cover nipple like yours has now. Don't eliminate it.
You can buy the small fitting that goes into the coupler that the hose connects to.
HTH
HTH
HTH
HTH
Just found this here
http://forums.corvetteforum.com/c5-t...on-photos.html
HTH
HTH
The hose seems to be coming from the valve cover, and not the crank case valley cover.
Toque
Also would a plastic barbed fitting work for this
The premolded nylon hose (also a GM item) has a 90* snap-on fitting the connects to it and the other end connects to the valve cover fitting as in the picture. Think LS2 OEM setup.
BTW, the hose(s) from the valley cover are part of a completely different (pcv) circuit and are not tied into the fresh air hose we are discussing here.
Is this what most people are doing ?
Thanks guys !
C6's have this air line going into there coupler ? I never knew that. I'll have to look at one of my friends car's. This is stock C6 equipment ?
So the fitting that goes into the coupler is a separate from the nylon hose you speak of ? Any ideas on PNs of both parts needed ? (hose and fitting in coupler)
Thanks !
Toque
The small plastic fitting is a GM item and is available through Fichtner Chev or Gene Culley at GMPartshouse, etc. You just need to cut a small round hole in the coupler for it. The small Callaway metal version is the same thing except doubtless far more expensive.
Thanks !
Toque
Thanks guys !
Thanks !
Toque
Thanks !
Toque
The LS7 engines have the same fresh air setup, but their particular molded nylon hose leads all the way back over to the oil tank in the "corner" where your battery is.
I don't have the GM numbers, but as I said they are available. Again, look at the LS2 OEM set-up.
I just found this picture.
Looks like the C6's DOES connect into the rubber flex coupler before the Throttle body....
So this is stock C6 stuff huh ?
the hoses/tubes on the valve covers are fresh air intake lines that should bring in filtered air from anywhere after the air filter. You can even cap all those fittings on the valve covers and use a filtered oil cap. This is the first part of the PVC system, filtered air in.
The second part is the vaccum side. What I have found to work best is to use the later model LS6 valley cover with the built in PVC valve. This with a catch can inline too. The vaccum line hooks into the intake right behind the TB into the catch can then from the catch can to the valley cover vent tube. If you do not use the latest model valley cover with the built in pvc valve then you must have one inline between the intake and the valley cover.
The system works as a whole, fresh clean air into the top of the valve covers and out throught the valley cover into the intake.
hope this helps.
hope this helps.
hope this helps.
hope this helps.
I have a 2004 Z06 so I think I have the newer valley cover. I have a catch can installed right now on my stock intake too.
I need a diagram to understand where everything connects though. Picture is worth a 1000 words sometimes.
This is why I'm going to write a procedure on this for my web site to help others....
Thanks !
Toque
Thanks !
Toque
