instrument cluster hud question
I have an 02 convert with hud. I have a chance to purchase an 02 ZO6 cluster but it has an blank plate on the hud side. Will I be able to use my hud etc and install on a ZO6 cluster. Any problems. Thanks Ray
An '02 should have a HUD enabled instrument panel. You shouldn't have a problem.
Received 19,232 Likes
'20-'21-'22-'23-'24
According to the Corvette Black Book, all '02 Z06s came with the HUD - so if the one you are lookking at does not have the HUD controls there, perhaps it is not an '02 gauge cluster.
Thanks for the postings. I went ahead & purchased. The cluster has Z06 on speedo face. There is a blank plate on the hud switch side. The 1st Z06 was made in 01 and archives tells me all Z06's are hud ready hopfully I can combine clusters. Thanks for your help. Ray
should not be a problem, feel free to PM me if you have any problems, I have taken apart the clusters several times.
