Want these so bad... almost had saved up enough too but then lost my job. Got another one very quickly but it will take a little while to recover... for now... I will drool.
Do the headers always come with an X-Pipe? My Corsa Sport/Pace exhaust already has an X-Pipe? Also, do the High Flow Cats help pass emission inspections (I may end up in Arizona where they inspect)? Thanks
You can get headers without the X-Pipe
However
In your case, they will not hook up to your X-Pipe...
Yes, you can pass emissions with High Flow Cats and a tune
I have a 2010 C6 Z06 tuned with an Unichip piggyback.
About the check engine light coming on because of the headers:
Is it possible to tune out the rear O2 sensor with that kind of tune? (piggyback)
Is it the same thing for the off road pipes/no cats?
Thanks !
Thanks !
Yes,
You can tune out the rear O2's - Not sure about the Unichip -
never heard of/used it before
Im looking for the 1 7/8 long tubes with x-pipe with cats. Which model should I be looking at? Are the pros and super pros both available in that size with cats?
If I were to pick up a set for my 02 c5 z06, the 1 7/8 lg super pros / x-pipe with cats, does it ship the next day? As in, are they in stock and ready to go out?
