Need Help with Codes
Ok I finally pulled the codes. I didn’t know that there were so many….This is the whole list that it pulled up. Hope you guys can help out…..Here it goes.
28-TCS C1226H
28-TCS C1233 HC
28-TCS C1255H
28-TCS C1281H
28-TCS C1286HC
28-TCS C1291H
28-TCS C1293H
40- BCM B2723 H
60- IPC No Codes
80- Radio No Codes
99 HVAC B0361 H
99 HVAC B0441 H
HO- LDCM B2282 H
HO- LDCM B2284 H
HO- LDCM B2264 H
HO- LDCM U1064 H
HO- LDCM U1096 H
HI - RDCM B2283 H
A1- RDCM B2285 H
A1- RDCM B2265 H
A1- RDCM U1064 H
A1- RDCM U1096 H
A6- SCM NO COMM
BO- RFA U1255 H
BO- RFA U1096 H
BO- RFA U1064 H
BO-RFA U1016 H
BO- RFA C2100 H
BO- RFA C2105 H
BO- RFA C2110 H
No More Codes
28-TCS C1226H
28-TCS C1233 HC
28-TCS C1255H
28-TCS C1281H
28-TCS C1286HC
28-TCS C1291H
28-TCS C1293H
40- BCM B2723 H
60- IPC No Codes
80- Radio No Codes
99 HVAC B0361 H
99 HVAC B0441 H
HO- LDCM B2282 H
HO- LDCM B2284 H
HO- LDCM B2264 H
HO- LDCM U1064 H
HO- LDCM U1096 H
HI - RDCM B2283 H
A1- RDCM B2285 H
A1- RDCM B2265 H
A1- RDCM U1064 H
A1- RDCM U1096 H
A6- SCM NO COMM
BO- RFA U1255 H
BO- RFA U1096 H
BO- RFA U1064 H
BO-RFA U1016 H
BO- RFA C2100 H
BO- RFA C2105 H
BO- RFA C2110 H
No More Codes
The battery was draining down about every 2 days. I found that the driver’s seat motor was running like it had a short in it. I just disconnected the seat motor and it hasn’t drained the battery down since. I will try to drive it like you said and see what that does…Thank you Sir….
