No intermittent wiper speed
One day I raised the wiper control lever one click on my daily driver and instead of getting the usual intermittent speed, the wipers ran regular speed, as if the lever was set to the second click.
Lifting the lever to the second click ran at regular speed, and the 3rd click, high speed. But when I dropped back to the first click, I still got regular speed.
Then, if that wasn't bad enough, the other day I pressed the lever down to activate one swipe and return to home position. I got my one swipe, but the wiper stopped midway down the windshield.
In both cases, running quickly through all the wiper adjustments (to try to clean the contacts) got everything working properly. Then it happened again another day.
I was considering replacing the wiper control lever, but I was told that the switches just tell the wiper motor what to do and electronics in the motor assembly determine the wiper arm position.
Any thoughts?
Any thoughts?
I believe there is just the one near the battery on the passenger side. I and many others have clipped the ends off the utters to prevent clogs. I understand the passanger side one is a pain to re-install.
You're welcome. But I gotta learn to wait before posting things like this. I posted a solution on another thread after I "thought" I had a fix. Symptoms returned.
Regarding the subject outcome, the wipers have been working fine for several weeks now.
