You may be able to buy new from the dealer but if I were you I would check out the wrecking yards. You wont have to find a Corvette wreck either. The manual controls used in the Corvette were used in a lot of cars over the years. My 95 Impala SS has the same control panel and *****, all the Caprices from that era also used the same controls.
Originally Posted by TitusPullo
Does anyone know where I can find a temperature control **** for a manual heater/ac control for a C5 corvette?
Are you looking for the **** only? As f6john said you might try a salvage yard, but if it comes from a different vehicle (truck/van, etc), just check the back side where it pushes on to the shaft to make sure the "D"-shaped hole is oriented the same way. Not all GM ***** are.
Maybe give Marc at Vettenuts a call too. He may have some.
