what oil to use
what oil to use
The former owner of my 98 vette said he used 10-40 napa synthetic since he owned the car, so today I go to napa and had synthetic 5-30 for $3.50 a qt, bought a case, I know owners manual recommends 5-30, will there be any probs with me returning to 5-30, Thank you guys for all the knowledge I have received from this site!!!
Received 19,302 Likes
'20-'21-'22-'23-'24
The car will do just fine with 5W-30 oil in it instead of the 10W-40. I use Mobil 1 full synthetic in mine with that weight.
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23
Oldtimer
Oil specs are important to pay attention to, . . .
Your going to get a hundred "expert" poinions, but for me, The guys who work at GM powertrains division and they said 5W/30 with a oil that passes GM4718M. Good enough for me. I have enough crap to want to re-engineer, but I'm not going to argue with the experts who built my Corvette.
I'm sure your owners manual will clearly instruct you to use a 5W/30 synthic with a GM Specs GM4718M, that's and important heat engineered additive in the oils package. My 2003 came with Mobil-1 5W/30 and it's never failed in any way for me so why change.
I would return to the recommended 5w30 as outlined in the owners manual. Mobile 1 is what I use in the Corvette but my other vehicles get Castrol 5w30 blend. There are other good choices, just stay with the correct viscosity and you'll be fine.
Okie
Okie
Why the hell was he running a 10w40 oil? Jeez... If its stockish there's absolutely no need for that.
I'm running 5w30 Mobil 1 full synthetic in my Z06 and 02 Trans Am. You can catch some good deals at the part stores on it. Usually 5qts and a Mobil 1 filter for $30, even though you'll need more oil.
