Oil Change ?'s
Oil Change ?'s
From what I have read on here the C5 has to be jacked up some since the oil pan is flat. I don't have the equipment to do the oil change myself.
My question is do shops do this? as they mainly just have the car over the opening and drain the fluids?
Anyone have an oil change place in Fort Worth/ Mid Cities TX area they recommend?
You're correct. You need to get the car level to drain all the oil from the pan.
The problem with taking the Vette to a non specialist is to make sure they jack the car up correctly. You need jacking pucks. If the jack makes contact with the rocker covers they will crack. As its a bonded panel its an expensive fix. If they use a drive on lift or a pit then no reason why they can't do it.
I bought a pair of Rhino Ramps (the grey type) from Walmart and use a jack and stands under the rear frame. If you want to do it yourself, it'll be a minor investment to start but you'll save time and cash in future.
Received 1,227 Likes
St. Jude Donor '11
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Race Ramps
It's an easy DIY. Now is the time to invest in the equipment. It will save you $ over time plus you know it's done right.
I like the 56 inch Race Ramps for the C5 (I use these for my oil changes). They'll give you 8 inches of lift to work under the front which is plenty for an oil change.
You can use your jack to lift the rear a tad higher to get that last bit of oil out if you wish.
I tried the store bought ramps and never could get them to stay in place while driving up.
Received 2,679 Likes
2018 C5 of Year Finalist
I'd like to start changing my own oil on an annual basis (weekend driver) and while the car is up, remove the wheels for a good polish.
Banned Scam/Spammer
There is plenty of room for a low profile jack.
Some customers like to use the 10 inch wheel cribs with those ramps for oil changes. That give you 2 more inches in the rear to drain all of the oil out.
I'm switching my 8 inch cribs out for 12 inch cribs. This should be fun
Heck, it took my suspension a full 2 days to settle after I installed my new wheels/tires.
Banned Scam/Spammer
Available in 8, 10, and 12 inches.
I like these over jack stands when you don't need to remove the wheels due to the stable base with the cribs being under all 4 wheels. Plus you have extra room to get under the car without the stands being in the way.
Location: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
What little bit of extra oil that comes out after jacking the rear I stopped doing it. All I do is jack the drivers side from the rear jacking point with a puck. Then put a jackstand under the front a arm for safety. Swap the filter, remove the drain plug, get out from under the car and pull the stand. Then lower the car while it drains. Swill down a cold beer or two. Jack it back up, reinstall the stand, reinstall the drain plug, slide my drain pan out, temove the stand, lower the car, and I'm done. No need for ramps. No extra jacking. Easy is the way I like it.
I think everyone has misunderstood Christee's original question. It sounds like he is under the impression that the C5 needs to be NOT level in order to drain properly. I could be wrong but I don't think that is the case. I think any place with a pit would be able to do the job properly. Right?
Received 19,285 Likes
'20-'21-'22-'23-'24
I have always put my car up on some Rhino Ramps in front, then lifted the rear with a low profile floor jack to where it is slightly higher than the front end. Maybe not completely necessary to have the back higher, but I like to think it gets more of the old oil out and it's really not that big of a deal to raise it higher.
What do most of you drain your oil into? After it's drained, what is the best way to dispose/recycle?
St. Jude Donor '13
I drain it into an black round oil drain pan that has a pour spout. Once its full i pour it into containers and take it to advance discount, autozone, or even walmart. They all collect waste oil for free.
Took her in for the oil change since she needed inspection too.
It's like taking your kid to school for the first time. Having to trust someone and hoping they don't screw anything up down the road.
