Water leak
Water leak
I had a water leak somewhere in my convertible top. I replaced the vertical moulding and the one that touches it when the top is up. No fix. I sprayed water over the top and could not locate the leak. Out of frustration I bought a roof cover and would just put it on at night. One day, I went to lunch with former co-workers, on the way, my rear window just dropped down. Some time ago, I read on the Forum that it frequently happens to convertibles. I did the "Rhino glue" fix. No more leak ! Thanks, this Forum is great, and so are the guys that post on it. You can find just about every fix you will ever need, RIGHT HERE
Received 19,233 Likes
'20-'21-'22-'23-'24
on getting the water leak fixed. And I agree, this forum has a ton of useful information available.
Received 1,762 Likes
You know the car has set screws in behind the door panels that moves the window in and out. I had the same problem just have to play and read up on what screw does what to the window... Robert
