1999 Tire Questions
1999 Tire Questions
Tires need replacement on fronton 99 convertible. Hearing lots of different things.
Dealer recommended replacing current Goodyears with Michelin Pilot Sport PS/2 runflats.
1) How do the Michelins compare to others?
2) Are the run flats neccesary, or what are other options. Are they noisier?
Any other INFO would also be helpful.
Everyone has their own opinion on tires, I just replaced the Goodyear runflats with Michelin Pilot sport Plus A/S (non runflat) and I like them. They are quiet and smooth (any non runflat will be quieter and smoother than a runflat) You can also get the Michelin Pilot Sport Plus A/S in runflat form.
The Hankook Ventus V12 seems to be a popular, and cheaper, choice, but there are many others to choose from.
Go to Americas Tire web site and select your car and check out all the options.
http://www.americastire.com/dtcs/home.do
And, if it were me, I would replace the tires as a set.
Ditching the run flats is the best mod I(and others) have done. The cars drive completely differently. They are quieter and hold the road so much better you will think you are in a different car! You won't believe it!
Received 19,293 Likes
'20-'21-'22-'23-'24
If those are the original tires that came on the car, I would just replace all four. I replaced my Goodyear runflats with a new set of Hankook Ventus V12 EVOs and got all four for $656 delivered.
If I ditch the run flats, is there anything ele beside a can of fix-a-flat I should put in the car??
The fronts wore out faster due to mis-alignment (Recently purchased the car). Backs have plenty of life left, so that's why I was leaning on only the front replacement for now.I drive 90% suburban highway, with the rest urban (Live in Vegas). No racing at all. Any other tire recommendations before I buy.
