★★★★★★★★★ ► CHUCK CoW NOW REPAIRS 1997 - 2000 DISCONTINUED C5 ABS UNITS ◄ ★★★★★★★★★
Received 1,981 Likes
so Chuck I have a code 1255.......bad ecbm with sub codes m0 and m6 according to the dealer who pulled the sub codes...whatever they are. does your fix fix that..........oh I hope it does.
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
C1255......
They are mostly for the use of the GM engineers when talking to the dealer techs.
I have to imagine they suggest to check all wheel speed sensors anong with power and grounds first....
After that we gotta tear it open and check the areas where I fix them...
We could fix one in advance and then swap it out to see if you get the same problem...
That's how I narrowed it down on the fix we did yesterday.
Chuck CoW
I have a 2001, but if I had an earlier model with an EBCM issue I would send it to him to fix out of honor for his efforts. You guys need to support him.
Agree 100%..... When the Ohio snow blows I'll pull mine off and see what we can see........ As long as it is the EBCM we are talking about which sits right behind the radiator on a 2000 model.
Former Vendor
Make sure you tell me all the symptoms and codes FIRST!!!
CALL ME BEFORE SENDING ANY ABS UNIT.
As I said earlier, I'll help anyone I can, but I can't promise to fix all of them,
Nor do I want to turn this place into a 97-00 ABS REPAIR SHOP.
Call first, let's talk about it....and if I can I will help you.
Having the whole car here is much easier cause I can do the diag myself
and then VERIFY it's right before sending it out.
Thanks!
Chuck CoW
#34
Thanks!
Chuck CoW
Thanks!
Chuck CoW
#36
Chuck
Does this fix apply to a 2001 C5?? I have the problem and have just been hitting the reset button.
Can you fix it in one day or do I need to leave the car overr night??
Fred
Fred
#38
Well done!. DId you buy a new relay? I realize you dont' want to sepnd all your time repairing, but if a relay change can fix it,, I have done the door module already on my C5 by changing the relay and not afraid to tackle another one.
#39
Former Vendor
This one is WAAAAAAYYYYYYYYYYYYYY......
By comparison, the Door Module is effortless.....
Chuck CoW
#40
Relay
Just hope you are ready for a good time doing this since Chuck didn't say it was a no brainer: just the opposite was implied. Good luck.
