Sigh!!! Jaw Dropping Bad News
Hi Gang,
Getting ready to store my '01 C5 Coupe with 29K miles on it. Ive owned it for two months and its my first Vette. I bought it from a private party.
Last week the Traction Control and ABS warning came on so I took it to a Chevy dealer to check out today. Yikes! $1700 for a EBCM and maybe another $2319 for a BPMV. I told them to hold off. I plan on storing it and researching my options until spring.
This leads me to you guys who are my "options resource."
What say you?
What say you?
What codes does the car have? Could be as simple as fixing some solder joints in the EBCM.
Thx Guys. Im looking into this further on this board and am finding some more info. Perhaps I can sort through an alternative. Appreciate the help.
Agreed. First, determine which codes the computer is giving and go from there. Take these issues one step at a time and you'll be able to figure most of this issues out with the help of the forum. Good luck!
Sweck, Having a C5 is a great thing but what's even better is being a member of the Corvette Forum. We have the best members you can find. If you are patient the guys will find a way to help you out with the right info. I've seen some new members come on to strong and they wonder why no one helped them. Good luck with your C5 and welcome to the forum.
Love this forum...what a great bunch of people. I appreciate the help and am not feeling so overwhelmed by the dealers diagnosis. Thanks again everyone!
If this happens when you start the car then check this thread out as well ..
http://forums.corvetteforum.com/c5-t...ch-repair.html
My 98 Coupe was plagued with this for sometime before I replaced the ignition switch and that fixed it. It is back again nowadays so it might be time to replace or clean the switch innards again.
Unlike the 1997-2000 EBCM Control Module the 2001-2004 can be repaired and as stated ABS Fixer www.absfixer.com can usually do it -
You can pull it off while in storage and send it to him and get it repaired! It is easy to remove.
Do not be fooled into buying the ABS Pump that is "NOT" the problem - the problem is the Module that separates off the ABS Pump!
Thanks,Matt
Thanks,Matt
How is that possible, 29k miles and you have these issues? I would get a second or third opinion on what needs to be replaced/repaired..something really smells fishy in Norway!! (repairs seem to be done on the basis of replace parts till it is fixed) Good luck and keep us posted, Rob
A T T E N T I O N !
It appears we have someone here who can repair the '97-'00 ABS
http://forums.corvetteforum.com/c5-g...abs-units.html
Thanks,Matt
Thanks,Matt
Location: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I had the same issue and sent off my unit to http://www.absfixer.com/ for repair and it cost 150.00 From when I sent it out and got it back was about 5 days.
This was 2 plus years ago and still works great.
Mr.Bill
Mr.Bill
Received 19,275 Likes
'20-'21-'22-'23-'24
