ac delco battery question
have to replace my 2004 top post # 86 battery. will replace with
pt# 19001632 ac delco #78PS-6yr . it has 700 CCA & 120 RC.
i know some of you have done this before, but the new battery
has side mounts for cables. did you have to bend clamp ends to
use or is there an adapter for such . i can't find one. if i bend
clamp end ,will it break. or what? thanks, jerry
Received 2,680 Likes
2018 C5 of Year Finalist
I believe GM began to swap out the battery styles/clamps mid year during the 2004 production run in preparation for the C6.
I also think you're better off finding a replacement battery with top posts vs. swapping out battery cables. I don't believe you can bend the clamps and I'm not sure about adapters.
Check Autozone, Pepboys etc.. There are adapters made that bolt to the side mount battery that have a post on them to attach your cables. Something like this:
http://www.crutchfield.com/p_211BAST...r.html?tp=2681
One other question. Someone mentioned that the delco. 78-6yr battery
Can be bought with top mount posts. The ones that I saw were side
Mount. If so, what is the part no.? I want the 78ps-6yr series as it
Has 700cca & 120cr.thanks-------jerry
From another thread this shows a dual terminal Professional. Doesn't have the p/n though-you'd need to research:
http://www.batterysales.com/delco-pro.cfm
