01 headlight motor
Old 12-13-2012, 04:12 PM
Vettdudez06
6th Gear
Vettdudez06's Avatar
Default 01 headlight motor
If i replace the gears in my headlight motor, will the grinding noise stop?
Old 12-13-2012, 04:15 PM
pewter99
Support Corvetteforum!
pewter99's Avatar
Received 1,194 Likes on 704 Posts
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
yep....
Old 12-13-2012, 04:20 PM
Vettdudez06
6th Gear
Thanks. i also need to replace my relay's in both doors so my power windows will work. Any suggestions on suppliers?
Old 12-13-2012, 05:10 PM
rbrumm
rbrumm's Avatar
yes gear replacement
spend the money and get the brass ones. there are a little pricey but you will only replace them once. I replaced one gear about 4 months ago with the stock plastic type and it has already started having issues . I just replaced both gears a few days ago with the brass gears and everything is back to normal. Make sure the drive motor is tight to the plastic housing. Hold the plastic housing and try to move the motor if it moves than you should tighten things up .
You can tighten it up by bending in the four tabs that connect the steel housing to the plastic one. Put it on a bench and with a nail set type of tool and a hammer bend in all the tabs until things tightens up thats it .
Cheers
To 01 headlight motor
Quick Reply: 01 headlight motor
