Side View Mirror Issues
The electrochromic auto dimming feature on the driver's side view mirror on the 2001 vert I bought a couple of weeks ago has crapped out. (permanent gold tinting and double image). I bought a $55 Panavex wide angle stick on mirror instead of the $200 GM mirror since I figured I could live without the dimming function and I'd gain a wide angle view without blind spots. The Panavex mirror is not working out due to distortion that makes it unusable. I'm considering buying a GM replacement mirror (glass only) for about $75 that does not have the Electrochromic function. Has anyone done this and if so does it cause any computer code problems since the original mirror had the function?
Have you looked over in the parts section? maybe someone is parting out a vette and you could get a used one. That would have to be cheaper and then you wouldn't have to worry.
I would double check the connections if you haven't already. Maybe you have a loose connection, a frayed wire, or blown fuse somewhere. Look for easy things first.
http://www.wheelskin.com/burcomirror...irror=BUR-2835
Boy you are into this mirror for $55- plus another $75- for replacement plain mirror only $70- away from the correct part...personally I would have purchased the correct mirror off the hop and be done with it. it is not such a crazy expensive part!? I can see another post coming regarding this mirror issue. (in this case its better to bite the bullet)
Thanks for all the tips.
I decided to go with the basic mirror (non-heated and non electrochromic) from Fichtner's Chevy for $78. I'll pop the old one out and pop the new one in and forget about it. Don't need the heated model down here in New Orleans and I'll survive without the dimming feature.
Maybe I can separate the Panavex mirror from the defective electrochromic mirror and sell the Panavex to recoup a few bucks. Worth a shot I guess.
CF "Young" Senior Member
Sorry to hear the panavex wasn't working for you, I'm absolutely loving mine. The wider field of view is initially a little jarring, but it's come to make driving a lot safer and convenient for me.
I'm getting a double image. If I close one eye it looks normal but when I open the other eye it looks like I've had way too much too drink. It's just not working at all. Don't know if I can get a refund or not. The Panavex is stuck to the original mirror pretty good. I guess I could send the Panavex back to them still stuck to the original mirror since I'm replacing it with a factory mirror.
I love my Panavex - great coverage of the blind spot. I had no adjustment issues and no distortion or double image. Try following up with Panavex - yours may be defective.
Good luck.
K9Leader
Red cars are faster. They did a study on it.
Good luck.
K9Leader
Here was my solution. Twenty bucks including shipping. Has been on the car for about 3 months now and his holding up just fine.
http://www.wheelskin.com/burcomirror...ETTE&year=1998
