Oil Filter
I use NAPA GOLD (same as WIX), it has good flow AND filtering.
I used to use DELCO Premium and Mobil 1 filters, but found that they restricted flow somewhat.
Received 2,706 Likes
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16'-'17-‘18-'19-'20-'21-'22-
'23-'24
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Wix for the win.
Most are made by the same few companies either way. Check out this great thread (scroll down the thread)
http://forums.corvetteforum.com/c6-c...vs-upf48r.html
Wix for the win.
Toque
be careful when you use the K&N oil filter cause that tighten/losen nut on the bottom becomes a low point and could risk hitting something with the K&N compared to other brands
Received 19,279 Likes
'20-'21-'22-'23-'24
I have always used the AC Delco PF-46 filter.
Location: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
I've been using the Amsoil EA15K32 for a couple years now, but just realized the WIX 51042 is just as good, and a couple of dollars less. I might just move to that one on my next oil change....
Location: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I use Wix or Napa Gold, I would never use a K&N filter for the simple reason it has a bolt head on it to remove it and if you look at it under the car it hangs down really low asking for trouble.
KN here. My car is slammed and the nut on the filter has never had a single mark on it from touching anything. Plus that nut is really helpful for easy install and removal.
