Rear C5 Zo6 WIDE Tire Sizes
Wanting to Widen my rear wheels or find a Factory Zo6 Replica wheel to match my stock wheels wanting the widest Wheels and Tire I can fit on my Lowered Z06 w/out rubbing issues
Id like width and Tire sizes for 18s and Pics would be sweet!
I have 18 x 11 CCW Classics on the rear with no rubbing and no cutting of the ducts either. CCW can provide you with the correct offset to go as wide as 11 1/2" but then you have to remove the Z06 brake duct. 11" fits without sticking out. I use stock size tires, 295/35-18 Vredestein now, I use to have PS2's.
Night Owl for life
Received 3,246 Likes
if you widen them you will need either flares or a tub for it to look correct.
Ya I dont want them sticking out and kicking stones up on the Paint, I was looking under it and The wheel is so close to the Mono leaf already I dont think u can put alot wider of a wheel on it than a 18x11
Nitto 555rII's in 305-35-18 on a stock C5z 18x10.5 wheel in back. Looks perfect and handles 800+ hp fairly well.
Rear --325-30-19x12
Front -275-30-18x11
Here's mine with my buddys C5 on the left, I have 295 and they are pretty wide on C6 Z06 rims (18X10.5) no rubs and looks great over stock size (see my buddy's). If you think you want 305, 315 or 325s in the rear you may have rub issues and you really aren't going to see a real difference in width, the 295 are nice looking and no interfering with suspension or wheel well shields. Good luck on your quest...
Michelin PS2's - Fronts - 265/40/17 & Rears - 315/30/18, mounted on stock polished Z06 speedlines, lowered on stock bolts.
