Wheel Weight
Old 02-06-2013, 08:08 PM
chasboy
chasboy's Avatar
Oldtimer
Default Wheel Weight
I've seen this discussed sporadically, and a search did not provide what I'm looking for.
Is there a 'list' of wheels which includes their weight, perhaps in some kind of ascending or descending order? How do aftermarket wheels compare in weight to stock Z06 wheels?
Thanks!
Old 02-06-2013, 09:03 PM
James2002z06
James2002z06's Avatar
Default Ill go first .....
When I purchased my Z it had aftermarket wheels... I Forged
Since then I have purchased Replica 09 Spyders and yes they are some what heavier than the others I took off the car ... As for the performance of the car there is no difference , maybe with huge tires that I now have it may corner a little better ... As your going to find from members like BK and a few others their thoughts are as mine , do you want to spend
4000.00 or do you want to spend 2000.00 ? That's a question that you have to decide ...
Good luck with your quest ...
Old 02-06-2013, 09:19 PM
chasboy
chasboy's Avatar
Oldtimer
Thanks! But that's part of my problem. I LIKE the style of my wheels, but some of those aftermarket ones are so jewel like. I think CCW makes a few?
Old 02-06-2013, 10:41 PM
Dave68
Dave68's Avatar
Taken from one of the stickies in the tech section:
Wheels
19.2 lbs, front; 21.4 lbs, rear - 97-99 OEM wagon - Src
22 lbs, front; 29 lbs, rear - 97-99 OEM wagon - Src
17 lbs, front; 19.5 lbs rear - 97-00 OEM magnesium - Src
17.5 lbs, front; 19.5 lbs, rear - 97-00 OEM magnesium - Src
18.08 lbs, front; 20.06 rear - 00 OEM standard, thin spoke, high polish - Src
17 lbs, front; 20 lbs, rear - 00 OEM standard, thin spoke, painted, no sensors or centercaps - Src
16 lbs, front; 20 lbs, rear - 01 OEM standard high polish - Src
19.6 lbs, front; 21.4 lbs, rear - 01 Z06 forged - Src
19.2 lbs, front; 21 lbs, rear - 02-04 Z06 cast/spun - Src, Src
24 lbs, 18x10.5 - 00+ repro high polish - Src
28 lbs, front; 32 lbs, rear - Z06 chrome repro - Src
23 lbs, front; 26 lbs, rear - Z06 chrome repro - Src
23.5 lbs, front; 24.5 lbs, rear - Z06 Motorsports, polished - Src
20 lbs, 17x8.5, 58mm offset, front; 23 lbs, 18x9.5, 65mm offset, rear - PWO - Src
22 lbs, 18x10.5, 58mm offset, front - HRE 545 w/clear center - Src
27 lbs, 18x12, 74mm offset, rear - HRE 545 w/clear center - Src
24/25 lbs - Z07 wheel weight, front - Src
28 lbs - Z07 wheel weight, rear - Src
Old 02-07-2013, 12:40 AM
chasboy
chasboy's Avatar
Oldtimer
Of that list, which ones are stock Z06 wheels?
Old 02-07-2013, 01:52 AM
striper
striper's Avatar
Chas, in my experience most aftermarket wheels are heavier than stock wheels. GM specced (sic) all Z06 parts as light as possible. The CCW Classics are one of the few wheels that lighter than stock, but not by much. Probably a pound or two at the most.
mjlorenson (12-16-2022)
Old 02-07-2013, 05:30 AM
chasboy
chasboy's Avatar
Oldtimer
Thanks Jeff, from what I'm reading here, I'm sticking with my stock wheels.
Old 02-07-2013, 03:01 PM
Dave68
Dave68's Avatar
This is why I'm sticking with my OEM high-polished wheels - only 16 lbs each for the fronts and 20 for the rear - not bad for the $1200 extra I paid.
Old 02-07-2013, 04:27 PM
PhysicsDude55
PhysicsDude55's Avatar
I found this little gem on the internet:
http://teamspeed.com/forums/aventado...orsepower.html
They did some dyno runs with different wheels on.
To sum it up, the difference was about 1hp/tq gained for each pound saved on a single wheel.
I.e., if you switch from 20 lb wheel/tires to 19lb wheel/tires, then you in theory gain 1 hp/tq.
In reality the difference is smaller than that, because of how a dyno measures power. Its probably about 1/2hp. Wheel size also comes into play. Larger wheels have a more exaggerated effect. Going from 20lb 18" wheels to 20lb 19" rims will cost you some hp, I'm not sure how much though.
So yes, putting 30lb aftermarket cast wheels in place of 20 lb stock wheels will cost you power, but only 5hp or so.
Depends on whether you think 5 or so hp is worth the extra $2000 of going forged. But of course Forged wheels offer more than just lighter weights, they generally look better and are stronger.
Another thing that I noticed, are stock Camaro wheel/tires really 72 lbs??? That seems really high, I was expecting more like 40lbs.
To Wheel Weight
Quick Reply: Wheel Weight
