C6 Style Suede/Leather Shift Knobs For Your C5! **$99.99**
Old 02-18-2013, 08:26 PM
0corvettemods1
Former Vendor
corvettemods1's Avatar
St. Jude Donor '12-'13
Default C6 Style Suede/Leather Shift ***** For Your C5! **$99.99**
Finally, a solution for C5 Corvette owners that want to add some customization to their car without breaking the bank!
Our new custom modified C6 shift ***** easily fasten to your stock or aftermarket shifter without any modification or hassle. Install in under 5 minutes and have the custom look of suede or leather depending on your stitching selection.
If you seek the touch of suede, select from our Red or Blue accent stitched shift *****. If you want to fire it up with Yellow, your **** will be adorned with 100% genuine leather!
To further your new look, add our matching suede or leather shift boots. A perfect compliment to your new shift ****.
ON SALE $99.99
Add the matching suede/leather brake boot for $89.99
Click To Order:
http://www.corvettemods.com/Corvette...ed_p_7943.html
corvettemods1 is offline
Old 03-03-2013, 08:29 AM
mre1974
mre1974's Avatar
Are the shifter boots and parking brake boots available separately without the shift ****? Does the shifter boot come with the plastic ring to secure it to the center column surround plastic?
mre1974 is offline
Old 03-03-2013, 12:09 PM
0corvettemods1
Former Vendor
Yes, we can sell you the boot by itself. It comes with a retainer, but we recommend you reuse your current one for a more oem fit.
Old 05-06-2013, 02:29 PM
All_Motor_C5LS6
All_Motor_C5LS6's Avatar
ON SALE $99.99
Click To Order:
I'll be ordering one soon!
All_Motor_C5LS6 is offline
Old 06-02-2013, 11:56 PM
Robert 2000
Robert 2000's Avatar
Does this **** just screw on?
Is there anything to stop it from wanting to spin around. I have a hurst shift **** currently and it has a backing washer that screws up to it and tightens it so that the **** does not turn maybe I can use this same thing and just screw this **** down to it?
Robert 2000 is offline
Old 06-03-2013, 12:03 AM
0corvettemods1
Former Vendor
Its not needed, this part will tighten up without and and will stay tight.
Old 06-04-2013, 12:49 PM
Robert 2000
Thanks will be ordering soon
Old 10-08-2013, 07:03 AM
5.3Avalanche
5.3Avalanche's Avatar
So what holds this **** tight on the shift rod? The stock C5 **** has a "key" that locks the **** in place so it doesn't rotate. Does this **** have the same style of lock? Can you please elaborate on how it "tightens up". Maybe with some pictures?
Thanks.
5.3Avalanche is offline
Old 10-08-2013, 10:14 AM
0corvettemods1
Former Vendor
Thanks.
Its threaded. There aren't any aftermarket ***** that use that key anyway. Once its tightened, its not going anywhere.
Old 10-08-2013, 12:41 PM
5.3Avalanche
I guess my question has to do with orientation. I understand that once you apply torque to the **** and tighten it on the threads that it won't turn anymore, but what if the **** tightens and ends up being 180 degrees from where it should be rotated? So this means you have to back it off by a half turn and it's no longer "tight". I've never had an aftermarket **** so I'm not aware of what your competitors use. Do you recommend using blue loc-tite or teflon tape around the thread so that it locks it on?
Old 10-08-2013, 12:57 PM
0corvettemods1
Former Vendor
You could, but its really not necessary. I use this **** and its tight
Old 10-08-2013, 02:10 PM
SDS Photography
SDS Photography's Avatar
Link to just boot?
SDS Photography is offline
Old 10-08-2013, 02:32 PM
0corvettemods1
Former Vendor
Originally Posted by CrazyInBlack
Link to just boot?
http://www.corvettemods.com/Corvette...es_p_5591.html
Old 10-19-2013, 01:18 PM
SDS Photography
I just ordered your light deal - why did I forget about this?
Old 10-19-2013, 01:38 PM
0corvettemods1
Former Vendor
I don't know! Get that order in and we will cover your freight!
Old 10-19-2013, 01:49 PM
Marine One
Marine One's Avatar
Any chance you'll be making these in colors that match the 50th anniversary interior?
Marine One is offline
Old 10-19-2013, 01:52 PM
0corvettemods1
Former Vendor
These are GM made, they aren't customisable. thx
To C6 Style Suede/Leather Shift Knobs For Your C5! **$99.99**
Old 01-07-2014, 09:15 PM
Dollars
Dollars's Avatar
The shift boot link didn't say its for c5
How I'm gonna order it?
Dollars is offline
Old 01-07-2014, 10:32 PM
0corvettemods1
Former Vendor
Yes it is. Order from the link and you will get the correct prodcut
Thx
Old 01-13-2014, 02:49 PM
Dollars
Dollars's Avatar
Just recived my order
I order the boots
Not ****
Please check
Dollars is offline
Quick Reply: C6 Style Suede/Leather Shift Knobs For Your C5! **$99.99**
