Discount Tire ect to install wheels.
When I went they said they did of course this was after I mentioned it first. The guy I use takes extreme care of my car. I now tip him cash also bring a pizza. You could always take them the wheels.
Go to a store and ask if they have sold/installed C5 wheels before. Ask them if they have "hockey pucks" for the frame slots. Their tire mounting equipment for large diameter wheels is usually the no-contact type.
Make sure they do a good job of balancing the tires; lead weights can't be used anymore so expect additional (steel) tape weights to be placed around the inside of the wheel.
My local Discount Tire store uses a type of scissors lift that has adjustable pads and I have seen C5's in the shop.
In my experience, there is no nationwide, universal training method for tire store mechanics. Discount Tire is just as likely to screw up you wheels/tires/rocker panels as Wal-Mart or Sears. Just depends on who's working the day you go in, what mood they're in, how busy they are, etc. You roll the dice and hope for the best.
Maybe if you're doing an oil change on a lift in order to keep the rear of the car a couple inches higher than the front.....other than that I can't see ANY reason to not be able to use hockey pucks at the front frame rail locations.
I used them without any issues, of course they said they knew how to jack it up. I watched to make sure they did know. All shops might say they they know the correct way if they do is another story.
The answer will vary with each store. Just go and ask them. They will tell you the method they will use to pick it up, that should either satisfy you or not. The Discount I use is very good and they have no problem with any corvette. But this does not say anything about other stores.
Hey, it ain't paranoia if they really are out to get ya!
Funny you should mention that. When I bought new tires for my C6 back in 2010, I did load up the tires & wheels and take them to the tire store. I had purchased new tires through Tire Rack and had em shipped directly to the store. The Tech somehow managed to break 2 of the TPS sensors! They replaced the broken sensors, but I had to hang around an extra 2 hours while they sent someone out to get new ones.
Where I came from in SoCal, we had one close by in Mission Viejo, and another in Lake Forest. The MV was small, dark, dirty. The LF one was large, clean, Mech's were pretty cool. They always listened to me when I said "NO LIFT"..only jacks for my M3 and the one time I took my Vette. I almost always spent time watching them, and we end up chatting cause most of them are Car guys too.
