corner light replacement
does anyone have instructions on replacing the DRL housings? and has anyone replaced the DRL socket on their own and have instructions on it?
Corvette Cowboy
yes I have and here is the thread to follow also look at the link in the thread
http://forums.corvetteforum.com/c5-t...placement.html
Pops
Pops
Corvette Cowboy
Check this out just scroll down a couple post and you will find the write up
http://forums.corvetteforum.com/c5-t...l-in-here.html
Pops
Pops
bookmarked, do you remember where you got the solid clears? on ebay they have chrome and black
that looks fairly simple and keeps me from having to pull the cover....which i was not looking forward to doing. i always scratch something when i pull front bumpers
Received 19,274 Likes
'20-'21-'22-'23-'24
Thanks to the link for the replacement of the turn signal housings. I need to replace one of mine and this will come in handy.
Loosen the sockets, pull down the brake vents in the front bumper, then pull the sockets straight through very carefully, replace the sockets making sure the wiring from the socket corresponds with wiring looms(by color), carefully push the sockets/wiring back through the brake duct, reconnect the negative battery cable, check the DRL lights to make sure they're working properly,if so, plug the sockets back in. It's all good. One of the easier DIY projects, IMHO.
