low idle
low idle
Hey guys i need help my 1997 C5 when it is warm the idle in drive is at 500 RPM .
The car wants to stall when you take your foot off the gas when you come to a stop and the RPM goes down to almost zero then i comes back up to 500RPM.
Any ideas on why the RPM's drop off like that.
I have a 98 C5 and I have the same problem. When I come to a stop sign, I put the trans in neutral so the engine won't die. I have heard it might be a dirty throttle body. I will be watching this thread for additional help.
Mine will die also but with the lights on it makes a difference.
The idle is still low but it dont stall.
Try it if you get a chance.
I will try cleaning fuel system T/B this weekend i hope it helps.
I just put i new trans in it and dieing to drive it.
It is like a new car trans is so strong all 2013 updates in it
Transmissions By Bruce in Ohio they are the best.
You have not said if you have any codes. If you have not checked, do that and let us know if anything shows up. Do it before you shut the engine off so if anything is there we will know what is H or C.
First clean the throttle body.
Have you had the battery disconnected recently? It is possible that the engine management system needs to relearn where the idle speed needs to be.
