AC Delco Alternator P/N? 2001 Z06
C5 COTM Coordinator
I'm looking into an alternator as preventive maintenance on my 2001 Z06. Sometimes i'm getting the "Charge System Fault" message on my car. I've checked the battery connections which are fine, i've looked at the wiring on the starter which also checks out. What i notice at times is surging in voltage with my current alternator in between 11v and 14v at times. It does this sometimes and then goes away. Anywho, i'd like to have one handy just in case it were to go out out on me. I've researched a couple possible part numbers but not sure which one fits my application. If something is wrong below please correct me.
1ST
AC DELCO P/N- 334-1280
GM Part Number- 19134273
2ND
AC DELCO P/N & GM Part Number- 10353440
1ST
2ND
334-1493 is the 150 amp version and $267 shipped at amazon, 334-1280 is the 110 amp version for 166 at amazon
curiously amazon doesn't list the 110 as being the correct fit for a c5, but, there is a lot of information on the net about the c5 having a 110 stock
orilieys has their house brand 110s for $160 or the 150 amp for only $190. beings the alternator is a 5 minute swap out their lifetime warranty may be worth considering
if you have an OE part number on yours you could match it up to one of these 4
http://www.oreillyauto.com/site/c/se...ette&year=2001
C5 COTM Coordinator
