What HID kit for ACA lights???
Location: ALL governments are legalized mobsters, so doesn't matter where I live :(
I just received my new ACA projector lights and plan on getting an HID kit. My question is, is there a difference from the HID h9 bulb vs the HID h11 bulb??? (55watt slim balast)
Check out my thread here, this would be the best path:
http://forums.corvetteforum.com/c5-g...-housings.html
Are the stock aca's not sufficient with hid's that they need to be modified or is just a further improvement on a already decent system? Thanks
Supporting Vendor
- Bi-xenon projector (allows the projector to function both as low and high beam with no additional light source needed)
- Correctly aligned low and high beam (from the factory, your low beam is NOT properly aligned with the highs.
- "tuned" projector optics for a more uniform light distribution on the road
- Significantly wider pattern to see objects on the side of the road as well as around turns
- Foreground limiter to reduce glare
- Direct plug-and-play HID kit included
More information.
http://forums.corvetteforum.com/c5-p...hid-power.html
They are a far cry from the candles of the factory lights, but if you're going to upgrade to HID anyway, you might as well upgrade to the best. The bi-xenon system I build offers many advantages including:
More information.
More information.
Got mine last year. Best money I ever spent. I was amazed at the difference it made.
