*Here's a great way to protect your lower radiator support/skid plates!*
#81
Supporting Vendor
Fangs from SacCityCorvette provide the best possible protection available for your front skid Plates/Lower Radiator support on your C5/C6/C7 Corvette.
#82
Had these on my '13, and liked them. Question: I will now have an '18. Is the radiator support setup the same/similar to the C6--meaning the same proclivity to scrape on a steep driveway--which is my only problem? If so, I assume you have C7 Fangs that function the same way. Correct? Thanx!
#83
Supporting Vendor
Hi Corvetteflier,
Yes the C7 have aluminum skid plates/ rad support like the C6. Here is a link for your C7.
http://www.saccitycorvette.com/C7Fangs.html
Thank you,
Christian
Thank you,
Christian
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
#85
Hi Corvetteflier,
Thank you,
Christian
Thank you,
Christian
#87
Figures...I already have the regular fangs but just bought an A&A SC....
#88
Supporting Vendor
Supporting Vendor
SacCityCorvette (02-28-2019)
#91
From an engineering design and a form, fit and function point of view, these are an inexpensive solution to already damaged radiator supports. They help with those cement stoppers at parking spots. They also hide any damage incurred prior to their install. This makes you very expensive radiator support visually new looking with a level of protection unmatched by the support itself. I rarely recommend anything, unless it is fully "vetted".. by my Vette, LOL. Mine have been on for over a year, took me 15 minutes to install, and they look as good as the day I put them on. Naturally, I have no affiliation with the product, or the vendor but always looking to point members in the right direction.
Bill aka ET
Bill aka ET
