*Here's a great way to protect your lower radiator support/skid plates!*
Supporting Vendor
Hi Everyone!
C5/C6/ C7 Corvette owners know that the front skid plates are vulnerable to getting bumped and scraped. Fangs from SacCityCorvette provide the best possible protection available for your front skid Plates/Lower Radiator support on your C5/C6 / C7 Corvette. Made of a High Impact Superior Performance Plastic, the C5/C6/ C7 Fangs are extremely impact resistant and 6 times more abrasion resistant than steel and Installation only takes a few minutes. Being only 1/8" thick you will not even notice any clearance loss. There is NO drilling or modification required! C5 Fangs are a simple 10 minute bolt on using your factory bolts.C6, you simply glue them on or if you prefer, they can be screwed if you order the screw on kit. It comes with drill bit and tapping screws. Once the Fangs are installed you will have the best protection available. $49.99 is a very small price to pay for such good protection of such an expensive part of your Vette!
(Note: we still have the screw on C6 Fangs for those who prefer them. Check our website)
2)The superior performance plastic we use is 6 times more abrasion resistant than steel making them slide very smoothly over what ever they come into contact with.
3)They perform perfectly in hot or cold weather.
4) They distribute the load over the entire skid plate where it is the strongest and can evenly distributes the impact, not on one side or the other where the side load can bend skid plate.
5)There are no moving parts to wear out.
6)They only weigh 5oz for those that worry about weight.
7)There is no drilling or modification needed to install them
8)The Fangs give protection over the entire skid plate. So if you bump up on a parking block like we demonstrate in our video you are protected from the front to back and from the highest point of the skid plate to the lowest.
9)They look like something that came on your Vette from the factory.
Here is a video of the Fangs getting used!
http://www.saccitycorvette.com/See-t...n-Action-.html
Here is info for the C5 Fangs
http://www.saccitycorvette.com/Fangs.html
Info for the C6 Fangs (Note: we still have the Screw on C6 Fangs for those who prefer them. Check our website)
http://www.saccitycorvette.com/C6-Fangs.html
Info for the C7 Fangs $66.95
http://www.saccitycorvette.com/C7Fangs.html
C6 Glue Fangs
C6 Screw On Fangs
Fangs will help prevent this from happening.
No gluing for the C5 Fangs. They bolt on with factory bolts.
Some of the Benefits
1) They are only 1/8” thick so there is no noticeable ground clearance loss. That’s very important since there is not much clearance there to begin with!2)The superior performance plastic we use is 6 times more abrasion resistant than steel making them slide very smoothly over what ever they come into contact with.
C6 Glue Fangs
C6 Screw On Fangs
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23
Oldtimer
Radiator supports protection ?
I install a set of your fans 8 years ago and they are great, but if your going to own and enjoy a C5 then you need to learn how to keep from crushing the radiator supports in your driving habits ? There's no better teacher than experience.
Received 3,812 Likes
I highly recommend this product...
Bill aka ET
Bill aka ET
Supporting Vendor
Supporting Vendor
Thanks Bent98 and ET!
Bent98 how long have you had your Fangs?
CF "Young" Senior Member
Definitely one of those items I will say you *want* to get if your C5's not a garage queen. Soooo many times I've been very glad I've got a set installed on my '01.
Just ordered mine, yesterday I hit a curb and it felt and sounded like I hit a wall. Shook me all up and I was being careful but misjudged the distance. Still getting used to the car..
Supporting Vendor
Would have been nice if they were installed before you hit.
Christian
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Supporting Vendor
The A&A SC Fangs are 1" longer to compensate for the A&A kit lowering of the lower radiator support. If you are getting a A&A SC kit then order the A&A Fangs. They will still fit your vette they will just be a little long up front in the body.
Christian
Supporting Vendor
Thank you callie for your business! They are on the way!
Got mine in white to match the car and put them on without a hitch. Look perfect and now piece of mind if I ever hit another curb. Thanks
