TPMS question
Old 06-22-2013, 03:04 PM
flags97
flags97's Avatar
Default TPMS question
I just put on new Hankooks, love them, great tire. When I got tires mounted and high speed balance done I picked up the car and had the TPMS service in the DIC, I said great, just need to program. When I got home I started the procedure and did not get horn beep on front drivers side tire, so I assumed that my magnet was not very strong. So I went online and ordered a round magnet. Anyway next day I take the car out and no service light and have a reading on all the sensors on the DIC. How does that work? Should I still have the service reading?DIC shows 32 on upfront tires and 30 on rears. Should I go ahead and reprogram when I get magnet? My vette is a 98.
Old 06-22-2013, 03:09 PM
pewter99
Support Corvetteforum!
pewter99's Avatar
Received 1,194 Likes on 704 Posts
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
they relearned themselves....do you still have the message? if so hit RESET
Old 06-22-2013, 03:15 PM
flags97
flags97's Avatar
No, I no longer have the message, did a reset the first time, so when do you have to reprogram or is that the newer year C5? Thanks for your answer.
Old 06-22-2013, 03:16 PM
Received 19,188 Likes on 13,911 Posts
'20-'21-'22-'23-'24
If you are getting readings on the DIC, the sensors should be working. I'd probably just keep an eye on the readings to ensure they are in fact working properly - check them also with a good air pressure gauge to verify that the pressure shown on the DIC is very close to what you get with a gauge.
Old 06-22-2013, 03:27 PM
pewter99
pewter99's Avatar
only have to reprogram if you get tires mounted and they don't relearn or they get swapped around side to side ..may be a few other instances but thats the main ones
Old 06-22-2013, 03:50 PM
flags97
flags97's Avatar
Thanks for the info, the DIC was very close to what my gage said, front were at 36 so I released air to get to 32 and rears were at 31, so all is well!!
Old 06-23-2013, 09:04 AM
rws.1
rws.1's Avatar
how old are your sensors? you might be nearing the end of the battery life and getting an occasional service TPMS message
Old 06-23-2013, 09:41 AM
flags97
flags97's Avatar
Really don't know the age on sensors, need to find out from former owner, but they are working fine now!!
To TPMS question
Quick Reply: TPMS question
