Running lights/turn signal
Old 06-29-2013, 03:30 AM
Chanda's Vette
Chanda's Vette's Avatar
Default Running lights/turn signal
I know, I know use the search. I've tried googling it and using the forum search. Found some issues similar but not exact. The driver side running light/turn signal acting strange. Awful pictures I know.
#1 unlock car with fob all lights work
#2 with car running running light on driver side not working
#3 & #4 headlights up both off and on the running light is on
Nothing I have tried will make light come on while the car is running and lights off or the turn signal work.
I've tried toggling the hazard switch turning the turn signal off and on no luck. I have read there is a blinker bi-pass that can be done or even the hazard switch to replace. Is that a fix for my problem though seeing that its not only a blinker issue.
Old 06-29-2013, 07:01 AM
Phanni
Phanni's Avatar
Received 1,731 Likes on 847 Posts
do you have hyperflash?
If so, replace that bulb (one filient is broken on that side.
Old 06-29-2013, 11:36 AM
Chanda's Vette
I only have hyper flash on the rear left taillights. On the front nothing, no hazard flashing no turn signal flashing.
To Running lights/turn signal
Quick Reply: Running lights/turn signal
