VATS key question
VATS key question
As pictured, I have a spare key so that I could lock/unlock the console or glove compartment without taking the key out of the ignition. Also just ordered a couple of VATS keys.
It should be the right one, as the ohms were checked. Would I be able to put blank key in the ignition and be able to turn it if I held the VATS key close to the ignition?? Or does the VATS key actually have to make contact?
Just want to be positive it works.
I have one like the bottom key works fine
Bought some on Fleebay and had them cut by a locksmith.
VATS keys make contact with the resistor pellet.
PATS do not. If you have a PATS chip near the ignition you could start the car but not a Vette.
