JW Halos Installed + HID's *pics
JW Modded Halos Installed + HID's *pics
Thanks are in order to "Maxx_Z06" for the new to me JW Halo Modded Tails and JW Motoring for one replacement Halo Taillight and for producing an extremely high quality product with excellent customer service to boot!
The install was a breeze and MAN are they bright! They really add an awesome updated appearance with the LED corners, tails and HID's.
Fog Lights only:
Brakes ON:
HID Headlights and Fogs ON:
Fog Lights only:
Brakes ON:
Really beautiful!!!
Could you please tell me all the parts I need to make my headlights like yours and the vendor to use? Mine are stock.
Thanks in advance.
Jeff
Thanks in advance.
Jeff
I went from stock as well and used CorvetteMods Low Beam HID upgrade kit as well as their HID Fog Light Kit. I chose the 8000K bulbs that were a bit more blue with their 55W slim ballasts and installed a resistor from them as well for the Low Beams. That was in order to ensure the buckets would raise and lower properly.
All bulbs are in the OEM Housings. And just a note when you are installing/attaching the ballasts to the car, make sure they are mounted far enough down so the buckets do not hang up on them. Good luck!
They reaaaaaaally make a difference. I neglected to do the HID High Beam kit because IMO there is plenty of light output with just the lows and fogs!
Forum Vendor Corvette Mods: Link to the aforementioned products.
http://www.corvettemods.com/Corvette...it_p_5530.html
The HID's require a little bit more juice to fire up so if I start it at night and flip the headlights on right away without starting the car I will still get some serious flicker from them. However start it and turn them on sometimes they will fire right up. If not rev it a bit and turn them off (back one click) and on again and they are good to go.
I have the Fogs on for the approach lights when you unlock the car (Can be done on the DIC) and even then once I unlock the car they noticeably get brighter as I walk closer.
Received 19,300 Likes
'20-'21-'22-'23-'24
Car looks great Mike. The LED halo tails sure give the car a different look from behind and definitely add to the visibility of the car. HIDs sure throw out the light also.
Received 4,505 Likes
U.S. Air Force
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Thanks!
I bought from JW
I bought my HID projector lights from JW, along with the harness that lets the HID low beams stay on when I go to high beams. Everything was excellent quality and the install was easy. I bought 5000K lights with 55 watt ballasts. They make a very nice wall of white light.
Low beams.
<p>
High beams.
<p>
Low beams.
<p>
High beams.
<p>
Former Vendor
St. Jude Donor '12-'13
Thanks!
You should never put HID's in stock housings...if your Vette was as high as a normal car you would be blinding everyone. Hids require the "focus" of a Projector housing. Do it right and you'll really be blown away by the lighting improvement.
You know it!
And thank you!
It is literally night and day! The 8K throws off a bit more blue than I would like but oh well. The 5K below are awesome as well!
That Hi-4 Harness is damn bright!
Couldn't be happier!
And thank you!
As far as the Halo LED's.... Can't believe I went as long as I did without them. They really add to the appearance of the car at night with the halo and when you get on them there is zero mistake that you are stopping! It is pretty awesome seeing them light up the signs behind you on the road with the directional on!
St. Jude Donor '13, '15
The headlights are working perfectly, and still very bright! The only difference I might have made would be to have gone with a projector housing like the ACA's instead of the OEM housing. And get the 8K temp bulb. The 5K is a bit too blue for me now. You lose some light output for the color you get and the color has grown old on me.
I too wish I went to projectors though. I really don't see much light output in mine and feel I could have done much better.
