mobil 1
#41
Federal regulations required that the ZDDP (wear protection components) be reduced by about a third from all non-racing, non diesel oils. The issue is finding a 5-30w with a higher ZDDP content. Our engines were designed to use the old Mobil 1 with the higher ZDDP content. This may be a bigger issue on engines with higher lift and duration cams than stock. Joe Gibbs has a 5-30 designed for such applications and claims to have a higher ZDDP level than other 5-30s.
#43
Premium Supporting Vendor
I'm biased, but I think this is a better choice for those looking for a "high" ZDDP oil that doesn't meet current API SN specs:
AMSOIL Z-ROD 10w30 Synthetic Motor Oil (Product Code ZRTQT)
(zinc – 1440 ppm, phosphorus 1320 ppm)
This oil is very similar to the AMSOIL Dominator Racing 10w30 I use in my stock LS6 at the track. They use the same top quality basestock and the viscosity is almost identical. The Dominator has a little
more ZDDP than the Z-ROD but it has no detergents or dispersants needed for daily driving and I change it about every 500 miles or so. The Z-ROD has enough detergents or dispersants for about 3-5k miles (or one year whichever first).
With a 10w30 vice a 5w30, you'd need to be a little more careful with engine warmup. I use 150F as a personal thumbrule - no heavy throttle, no high rpm until my oil is over that temp.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
AMSOIL Catalog
#44
St. Jude Donor '13
Thanks C66 those seem like some good options. I'm no expert, just try to learn what I can. I kinda lost confidence in Joe Gibbs Racing after watching their Toyotas blow up during recent Nascar races.
#45
Received 3,812 Likes
St. Jude Donor '03-'04
The F bodys don't need it because its not a bottom feeder.
For the guys who said all oil is the same, its shame people like that are allowed to post on this forum,, this is a place where people come to get good advice, not some asinine statement from some legends in their own minds
#46
St. Jude Donor '13
Because it doesn't have the heat package that the LSX engine requires. most engines do not run in the 220 f range. I've seen this engine run for 200,000 miles at this temp , but with out the heat package the oil will break down .
#47
You can't believe everything you read, especially on the internet. Using the wrong oil isn't like using the wrong gas. Wrong oil related ware may take a long time to develop and you won't realize it until you have a catastrophic breakdown. Wrong gas will get you pinging right away.
Things like thermal breakdown do to sheer and take a 200K engine and reduce its life expectancy to 100 K.
Ping can cause a piston to rupture, or wrist pin related damage or bearing damage, both connecting rod and mains, that's why the right octane and the right oil keep these motors running in the 400K range.. of course what do I know. WE designed this engine to run with these additives because Dave hill wanted the first 200K benchmarked American production engine in his C5. We delivered it on time and within budget. Prior to 1997, all North American engines had a benchmark of 100K.
Bill aka ET
#48
St. Jude Donor '13
Where do I sign up for your class on automotive technology.. Especially when it relates to the C5 platform and the LSX Motor. I need an education. Seems like you are someone I should listen too.
Bill aka ET
Bill aka ET
#50
St. Jude Donor '13
