Window Adjustment
07-26-2013, 12:28 PM
Window Adjustment
Does anyone know how to adjust the side windows on a C5 ? Thanks.
07-26-2013, 01:13 PM
The 'limit stop' is easy, just push the up button and hold it for several seconds when the window hits the top. The limit is then set. The other adjustment involves removing the door panel and adjusting the angle of the window glass. It is a bit more involved. The service manual has the full procedure.
07-26-2013, 01:30 PM
If you have a vert, you might need to adjust the top, not the window.
07-26-2013, 01:51 PM
'20-'21-'22-'23-'24
Here is the window tip in adjustment. I also added a few other files on wind noise.
07-26-2013, 02:05 PM
Thanks guys.
07-27-2013, 08:48 AM
Excellent resource...thanks...
Bill
07-27-2013, 12:41 PM
Quote:
Do any of these help if the window is loose movement in/out?
07-27-2013, 04:16 PM
08-29-2013, 01:19 AM
Mickeyrx70
Excellent info! Thanks.
08-29-2013, 03:40 AM
Location: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
MrGary2011
My driver window was loose and made a screeching noise, I had to replace the regulator.
08-29-2013, 08:42 PM
Those are fantastic! Thanks
02-07-2014, 09:49 AM
Boss75
GReat info thanks /
