Base C5 GM Susp Upgrade - C6 Z51 Sway Bars - C6 Z06 Shocks - At CULTRAG Performance!
Old 11-20-2016, 07:47 PM
  #241
chasboy
chasboy's Avatar
Oldtimer
Gene, I'm being lazy, but how difficult is this entire job? I'm not an amateur, but I keep picturing the whole suspension falling apart when I remove the sway bars. Also, are the shocks just unbolt and replace?
Old 11-20-2016, 10:09 PM
  #242
ArtGle
Support Corvetteforum!
ArtGle's Avatar
Default Suspension upgrade on Jackstands in my driveway
Easy Job.
I bought this from him in 2014.
Installed the whole thing in a few hours.
Took my time.
Jack Stands, hand tools.
Old 11-20-2016, 10:10 PM
  #243
ArtGle
ArtGle's Avatar
Look at the picture, the old (removed) parts are there with the new parts I bought from him. The sway bars he sells make the originals look anemic.
The shocks are 'fatter' too.
Dahc (03-05-2017)
Old 11-20-2016, 10:18 PM
  #244
ArtGle
ArtGle's Avatar
Default Shock install helpful hint
The shocks need to be 'compressed' to get them into place.
I used a zip extension cord to tie them into the compressed state for installation.
Leave them 'compressed' until you've got the top bolts installed.
Then untie the cord, allow them to extend, and put the bottom bolts in.
All done.
I also HIGHLY RECOMMEND that you get the metal end links for this.
"HIGHLY RECOMMEND".
Old 11-21-2016, 11:29 AM
  #245
c4cruiser
c4cruiser's Avatar
I've been thinking about the C6 Z51 sway bars and C6 Z06 shocks upgrade for my '02 coupe with Z51 but the car only has just over 34K on the clock. The shocks are original but I'm curious if shocks "wear out" over time?
The car is also lowered on the stock bolts; will that make a difference with the C6 Z06 shocks in terms of installation and ride quality?
Old 11-24-2016, 01:36 AM
  #246
patrickt
Premium Supporting Vendor
patrickt's Avatar
Lowering will not affect installation but may make for a harder ride. The old stigma of replacing shocks every 60k miles is long gone. Technology has advanced from the old days and not they are good until they fail.
__________________
Patrick Trageser
CULTRAG Performance
Your one stop source featuring the true experts for all GM Parts and Accessories, Lloyd mats, SLP Performance and Hawk Brake pads!
Order Your GM Parts at www.CULTRAGfactoryparts.com
patrick@cultragperformance.com
1-484-334-8833
Old 12-04-2016, 02:19 AM
  #247
chasboy
chasboy's Avatar
Oldtimer
Gene, is it possible to do the sway bar upgrade without new shocks? How would that change the car?
Old 12-06-2016, 12:07 PM
  #248
patrickt
patrickt's Avatar
Yes you can. It would still improve your cornering ability over the base bars
Thank you
Patrick
Old 03-08-2017, 12:07 AM
  #249
Crosis
Crosis's Avatar
Is there a kit part number to order the C6Z51 sways and the C6 Z06 shocks as 1 package or do we order them separately?
Old 03-09-2017, 11:19 AM
  #250
TreeonaBoat
TreeonaBoat's Avatar
Going to start putting some aside for this upgrade.
Old 03-10-2017, 10:06 PM
  #251
mre1974
mre1974's Avatar
With over 80,000 miles on mine since doing this install in 2012 I can't say enough good about this set up and with my dealing with Gene and Patrick. Great guys to deal with. I can tell that mine are starting to show some age but after 5 years and 80,000+ miles the C6Z shocks and C6Z51 sways (with metal end links) is still one of my favorite upgrades I did to my FRC.
Old 03-11-2017, 11:24 PM
  #252
patrickt
patrickt's Avatar
You would have to order them separatly
Old 03-11-2017, 11:25 PM
  #253
patrickt
patrickt's Avatar
Thank you for your feedback and kind words it it greatly appreciated
Old 05-10-2017, 04:29 PM
  #254
Crosis
Crosis's Avatar
Just ordered the C6 Z51 sway bars with ends.
Old 05-14-2017, 03:15 AM
  #255
patrickt
patrickt's Avatar
Thank you very much
Old 06-04-2017, 03:21 PM
  #256
finnfjr
5th Gear
finnfjr's Avatar
Thanks Gene,
I've received the z06 shocks and sway bars for my '97. The first run made today with new parts. What a difference��. The old F45 shocks were totally gone. The car sits a little higher but came down a bit after an one hour drive.
P.S you should mention to your overseas customers to use the ebay channel. The freight costs are way more affordable there than on your own webshop.
Thanks again for great products and service.
Stephan
C5 1997
Finland
Old 06-07-2017, 10:51 PM
  #257
Gene Culley
Gene Culley's Avatar
Originally Posted by finnfjr
Thanks Gene,
Stephan
C5 1997
Finland
Hello Stephan,
Thank your business and for the positive feedback. The kit does really make a difference!
Gene.
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
To Base C5 GM Susp Upgrade - C6 Z51 Sway Bars - C6 Z06 Shocks - At CULTRAG Performance!
Old 06-21-2017, 10:21 PM
  #258
Gene Culley
Order your C5 suspension upgrade from CULTRAG Performance.
Old 07-09-2017, 12:14 AM
  #259
patrickt
patrickt's Avatar
We hope you all had a great 4th and we thank you all for your orders
Old 07-09-2017, 08:33 PM
  #260
Friscojim
Friscojim's Avatar
I found out I have the Z51 suspension option - I;m assuming I can just swap out my shocks for the Z06 shocks? Anything else I should consider?
Quick Reply: Base C5 GM Susp Upgrade - C6 Z51 Sway Bars - C6 Z06 Shocks - At CULTRAG Performance!
